GFCI Screw Or Push In ? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 05-24-2009, 06:24 AM   #16
the Musigician
DangerMouse's Avatar
handifoot, i do not believe these types are meant to be wrapped. there are two holes for each screw.
just strip the wire, slip it in the back and tighten the screw!
gigs: i find it hard to believe that you could even attempt to put 3-5 wires into the backs without tightening them as you go, one at a time.
they'd just fall out. you pretty much HAVE to tighten each one as you go.....
DM
Old 05-24-2009, 11:19 AM   #17
Rewards Points: 1,514
A right angle bend is usually not enough to be held down by the screw itself, unless there are ridges in the nearby metal or in the surrounding plastic to keep the wire from slipping away, or unless the screw head has a ring like concavity on the underside to keep the wire from slipping out.
Old 05-24-2009, 01:14 PM   #18
Rewards Points: 150
Yeah, I guess your right. Even though I think it's a real tight connection and it's an outside weatherproof box that's a pain to put together with the screws through the plates and foam insulation, I will redo the connections before I energize the thing. Funny, it seems to me that I've always heard that the back stab type connections were an inferior design.
I'm gonna hurl myself against the wall
because I'd rather feel bad than not feel anything at all
Warren Zevon
handifoot is offline   Reply With Quote
Old 05-24-2009, 01:27 PM   #19
the Musigician
i believe you're thinking of the 'clamping' type normal outlets. seen 'em, replaced 'em, won't use 'em....
those seem to loosen over time, not so the screw-clamp style.
DM
Old 05-24-2009, 01:28 PM   #20
the Musigician
also, remember that if it's brand new, you need to push the reset/test button to turn it on after energizing.... lol
(been there, didn't done that, got embarrased)
DM
Old 05-24-2009, 02:00 PM   #21
Bigplanz's Avatar
Rewards Points: 990
Back stabbed is not the same as back wired. Back stabs rely on pressure from the metal holding in the wire. Back wired rely on pushing the wire in and then screwing down the connection. This is a very tight, very good connection. Back stabbing, not so much.
Bigplanz is offline   Reply With Quote
Old 05-24-2009, 02:56 PM   #22
Rewards Points: 150
Thanks to all, Mouse and Planz, I really appreciate your ability to laugh at your own mistakes. Your egos must be somewhat intact.
Warren Zevon
Old 05-24-2009, 05:08 PM   #23
Rewards Points: 894
I've been installing Leviton GFCI's, which are supposed to be back-wired, but...
I have had too many of them pull out during a moderate "tug-test" on the wires after seemingly secured by the screws.
After three or four pull-outs, I gave up, and started wrapping a full turn of bare wire around the screw, pinching it with needle nose, and securing the screw. Never comes loose.
I believe this is only a problem with the "cheaper" GFCI's. Yours from China would unfortunately qualify as cheap, in my opinion.
I agree that it is difficult to side-wire these critters. The screw doesn't want to stay out, but I solve the problem by putting a slight down-twist into the loop of wire I wrap around the screw. It takes patience, and some experience.
I would also be extremely careful with those China GFCI's when tightening the screws. While you need to get them secure so the wires don't pop out, and a good connection is made, you don't want to strip them out.
FW
Ultrarunner2017 is offline   Reply With Quote
Freezer tripping GFCI davidclements Appliances 58 07-03-2015 05:46 AM
Gfci Circuit howard.wheaton Electrical 10 01-29-2009 05:14 PM
new gfci on new circuit pops rtoni Electrical 39 11-15-2008 10:18 AM
GFCI Question Mdbuilder Electrical 6 06-19-2008 03:15 PM
GFCI questions 5circles Electrical 4 11-05-2007 08:24 PM
