GFCI Screw Or Push In ? - Electrical - DIY Chatroom Home Improvement Forum
Old 05-23-2009, 12:04 PM   #1
Rewards Points: 150
GFCI screw or push in ?
So, are the screw connectors on the sides of GFCI receptacles supposed to have the wires under them or are they only there to secure the push in from the rear. These screws are very difficult to get a 12g conductor safely under them.
I'm gonna hurl myself against the wall
because I'd rather feel bad than not feel anything at all
Warren Zevon
handifoot is offline   Reply With Quote
Old 05-23-2009, 12:10 PM   #2
the Musigician
DangerMouse's Avatar
the screws are there to lock the backstabbed wire securely. it'd be real hard to get 12g around those, for sure.
DM
Old 05-23-2009, 12:11 PM   #3
Bigplanz's Avatar
Rewards Points: 990
I struggled with wrapping wire around those recessed screw heads until if finally dawned on me that the screw heads are not meant for a wrapped wire. Putting the wire in the holes in the back, and screwing down to tighten them is how you are supposed to connect the device. I had a 'Der' moment when it finally dawned on me.
Bigplanz is offline   Reply With Quote
Old 05-23-2009, 12:11 PM   #4
The wire slips behind the pressure plate, not under the screw.
Some switches are being built like that now (P&S rocker switches). I always seem to strip and bend the wires (out of years of habit) and then look to see that the bend is not required.
220/221 is offline   Reply With Quote
Old 05-23-2009, 12:13 PM   #5
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,970
It'd be nice if you three agreed on something.
Old 05-23-2009, 12:16 PM   #6
We all agree on who is the biggest ahole here
Old 05-23-2009, 12:23 PM   #7
the Musigician
i believe he's looking at one like this. the pressure plate does not move nor do the screws come out very far to allow wrapping. (they wiggle and slip back in like hell when you try to get the wire around it)
stab and tighten only.
DM
Old 05-23-2009, 12:24 PM   #8
Bigplanz's Avatar
Rewards Points: 990
Since I have used them on GFCIs, I prefer the pressure plate, wire in the hole, screw down method. Seems much more secure, plus it's easier. I pay a little extra for that on a receptacle or switch, but it's worth it to me.
Old 05-23-2009, 12:28 PM   #9
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
DM,
Thanks for the posting the pic. Who makes that GFCI?
Disclaimer
& Stay Safe
.....Bob Lavery
Old 05-23-2009, 01:08 PM   #10
the Musigician
North Tech (china)
DM
Old 05-23-2009, 01:12 PM   #11
At least mine was light hearted joke.
Look at the post times of the first three replies.
Old 05-23-2009, 04:05 PM   #12
DIYer
The only problem with the pressure plate style is that it is entirely possible to install the outlet while forgetting to tighten the screws... And it may even work... for a while.
Gigs is offline   Reply With Quote
Old 05-23-2009, 09:19 PM   #13
Rewards Points: 150
Yep, mine's just like the picture. Nice to know I'm not the only one who struggles with this. I did manage to get the wires under the screws. It's not a great wrap around, more like a gentle right angle on the wire, but those suckers are very tightly secured under that #**##!! screw head. Next time it's the back stabs.
Warren Zevon
Old 05-24-2009, 01:52 AM   #14
Rewards Points: 506
Send a message via AIM to theatretch85
Yeah the pressure plates are nice on the regular outlets too, but since the code requires Tamper Resistant outlets, I have yet to see TR outlets with the pressure plates. Maybe the Menards store that I go to just doesn't carry them or I am not looking in the right place.
theatretch85 is offline   Reply With Quote
Old 05-24-2009, 02:40 AM   #15
As opposed to a mean spirited joke?
Well...I thought it was funny. Timing is everything in humor.
Freezer tripping GFCI davidclements Appliances 58 07-03-2015 05:46 AM
Gfci Circuit howard.wheaton Electrical 10 01-29-2009 05:14 PM
new gfci on new circuit pops rtoni Electrical 39 11-15-2008 10:18 AM
GFCI Question Mdbuilder Electrical 6 06-19-2008 03:15 PM
GFCI questions 5circles Electrical 4 11-05-2007 08:24 PM
