GFCI Replaced, Now What? - Electrical - DIY Chatroom Home Improvement Forum
Old 10-19-2010, 07:19 PM   #1
GFCI replaced, now what?
New homeowner here. This weekend I replaced the light fixture on the post in the front yard. When the lights would not illuminate, I checked a small electrical box on the front of the house and discovered some disconnected wires. After connecting the wires, the light worked for about 8 hours until it tripped a GFCI(no breakers) and shut off. I pressed the reset button about 10 time before it stayed in place. The light stayed on for several more hours before the GFCI tripped again. I then replaced the GFCI and encountered the same results hours later. Any suggestions?
Va Flyer is offline   Reply With Quote
Old 10-19-2010, 10:08 PM   #2
Electrical Contractor
kbsparky's Avatar
Probably a bad spot in the old underground wire
Dig up the yard, and install a new underground cable to your post lamp.
-KB
Old 10-20-2010, 02:33 AM   #3
" Euro " electrician
frenchelectrican's Avatar
I agree with KBsparky a good chance you may have bad spot on the cable or a nick somewhere along the way.
So unforetally you have to bury a new cable to slove the issue and with 15 or 20 amp 120 volt circuit with GFCI you can buried them 12 inch deep that is the only part you can do this otherwise any other size or voltage it have to be at least 24 for UF or Direct bural cable or 18 inch in conduit.
Also while ya digging up a new cable why not go with XX-3 cable so you have one on switched circuit for your luminaire while second part you can used for receptecale at the luminaire location.
Merci,.
Marc
Freezer tripping GFCI davidclements Appliances 58 07-03-2015 06:46 AM
GFCI Stumper ksqrdks Electrical 2 04-03-2010 07:24 AM
Replaced Outdoor GFCI Plug in Stucco? mfleming Electrical 2 10-07-2008 10:38 PM
GFCI Question Mdbuilder Electrical 6 06-19-2008 04:15 PM
GFCI replaced and not working Pullerwife Electrical 8 10-16-2007 01:50 PM
