GFCI Recepticle Vs. Breaker - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-17-2009, 11:26 AM   #16
Electrical Contractor
jbfan's Avatar
Rewards Points: 650
Originally Posted by Wildie View Post
Sometimes, even engineers make mistakes! In the case of the OP, he would have 30 amps available, instead of a mere 20 amps. Maybe someday the powers that be will see the errors of their ways, and make a revision!
Where did the 30 amps come from.
If you run a 15 amp mwbc, then you only have 15 amps.
The laundry area requires a 20 amp circuit, but does not mean you can't have other circuits in the area.
You can not leave the laundry area with that 20 amp circuit.
Old 01-17-2009, 05:53 PM   #17
Rewards Points: 508
Send a message via AIM to theatretch85
For what its worth, there is one 20 amp circuit feeding the laundry room here at my house that has run the washer and gas dryer simultaneously with no issues. Washer nameplate says 10 amps, and dryer nameplate says 6 amps.
theatretch85 is offline   Reply With Quote
Old 01-17-2009, 06:03 PM   #18
Electrician
Your situation meets code.
chris75 is offline   Reply With Quote
Old 01-18-2009, 10:11 AM   #19
Rewards Points: 156
Im curious... I ran a 20 amp GFCI circuit to my unfinished basement with conduit around the foundation wall. My 'laundry area' = my basement since it is wide open, no walls or doors. This circuit has receptacles that feed my washing machine, sump pump, and freezer all the time and other boxes around the basement for sewing machine, treadmill, etc... Am I in violation of code? The electric dryer has its own 30 amp circuit and the furnace is on its own circuit.
creamaster is offline   Reply With Quote
Old 01-18-2009, 12:04 PM   #20
Each breaker supplies 15 amps. or 1800 watts. 2X1800=3600 watts! One 20 amp will provide only 2400 watts of power! 30 amps IS a misnomer, and I should not have written it this way! It is in fact 2X15 amp circuits!
New GFCI Breaker Tripping w/ 3-way Flourescents BigJimmy Electrical 8 12-29-2008 02:29 PM
How to connect switch to GFCI breaker? firemanter Electrical 3 10-28-2008 07:46 PM
20 Amp Breaker tripping with GFCI panhandlion Electrical 7 12-12-2007 08:59 PM
GFCI outlet vs. breaker - GF trip speed LanterDan Electrical 2 01-09-2007 06:05 AM
GFCI breaker problems bwoo Electrical 5 12-09-2006 02:53 PM
