Gfci Receptacles Wired To Junction Box? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-21-2013, 10:49 PM   #16
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 3,410
John.... I think you're right to be cocerned...GFI's and breakes don't trip ouy of the blue.....
Can you think of anything else on those circuits, (or other circuits ) at that time.
Best
Peter
EDIT: Your GFI is end of run right... there is nothing on its load terminals right.
MTN REMODEL LLC is online now   Reply With Quote
Old 06-21-2013, 10:56 PM   #17
" Euro " electrician
frenchelectrican's Avatar
Originally Posted by JCosenza View Post
Hi MTN. The breaker was added to the panel Wed morning and that evening after work I was in the backyard and we heard the GFI trip. It wasn't being used. I tried to reset it and it wouldn't reset. I went to check the breaker and it was tripped as well. I reset the breaker and then I went back outside and reset the GFI. It has been ok since then but worried me that a brand new circuit would do that.
Very rare the GFCI can cause the breaker to trip if not functing properly espcally when you hit the test button it should not trip the breaker but if that do then you will have to replace the GFCI receptale.
They are not super hard to replace but please make a note which side is line and load connection this is very important and a common item when someone make a mistake by connected wrong which the new GFCI will not enable when it is connected wrong.
Merci,
Marc
Old 06-21-2013, 11:05 PM   #18
No there is nothing else.
From the panel > junction box > old white 12/2 > GFI it terminates there nothing is wired to the load side of the receptacle.
JCosenza is offline   Reply With Quote
Old 06-21-2013, 11:18 PM   #19
I think the breaker tripped and that's why the GFI did. The GFI was brand new. I know how to change them I've changed receptacles and switches before. I'm going to use my electric lawn mower tomorrow and if anything happens.
If there is something wrong I would probably want to change that old wire first there could be an issue with it somewhere that I cannot see.
Thanks everyone!
Old 06-21-2013, 11:29 PM   #20
Ok and did you manually test the GFCI there with the test button and reset it and do work normally now ?
Merci,
Marc
Old 06-22-2013, 12:47 AM   #21
Merci,
Marc
I did yesterday. I pressed the test button and reset the GFI. Then I used the drill plugged into it with no issues.
Old 06-24-2013, 11:08 AM   #22
Hi everyone, I just wanted to say thanks for those of you who helped me out. I did learn a thing or two from this. Glad the way the electrician did the job wasn't wrong or dangerous.
The breaker or the GFI hasn't tripped since last Wed. I used my lawnmower with it Saturday with no issues. So its functioning properly. I still do not know what caused the breaker and subsequently the GFI to go out last week. I will keep monitoring it and hopefully it will be ok.
If I do feel like changing the wire to the receptable would it be ok to run 12/2 BX shielded cable to the junction box to replace the old white 12/2? Reason being is because it runs through the crawl space.
For now I will leave it because I think if its not broken don't touch it. however I want to know if there's any thing I should know/do.
Thanks!
-John
Dimmer Switch wired to receptacles? TrailerParadise Electrical 20 02-02-2013 10:21 PM
replacing direct wired CO2 detector into junction box. Not sure which wire is hot bodiroti Electrical 4 11-08-2012 03:26 PM
GFCI as part of light circuit? iceracer Electrical 5 07-05-2011 08:05 PM
Gfci receptacles wire continuity test Hialeahn Electrical 4 03-05-2010 06:52 PM
GFCI between porch receptacles Thurman Electrical 4 08-19-2009 12:40 PM
