GFCI Receptacles - Electrical - DIY Chatroom Home Improvement Forum
Old 04-08-2008, 12:37 PM   #1
GFCI Receptacles
I know it might be a little redundant, but is there any harm in replacing all the outlets in a 69 yr old home with GFCI Receptacles? I know it's not needed but I was just curious about what problems that could cause if any. Also, If I were just to install one does it need to be put in a specific place, and is one really safe enough?
dankreboot is offline   Reply With Quote
Old 04-08-2008, 02:38 PM   #2
joed's Avatar
Rewards Points: 12,022
If there is no ground available the GFCI must be used unless you rewire.
There is no harm in installing GFCIs everywhere.
If you want to install oneGFCI to protect the entire circuit it must be installed as the first receptacle inthe line.
Old 04-08-2008, 03:56 PM   #3
Licensed Electrician
jrclen's Avatar
Rewards Points: 514
The first sentence is not true. The receptacles can be left alone, or replaced with new 2 prong receptacles.
There is no reason other then expense, to prevent you from replacing every receptacle outlet with a GFCI receptacle. But, installing a GFCI receptacle at the first receptacle outlet in a circuit, and then connecting the downstream receptacles to the load terminals of that GFCI receptacle, will protect those downstream receptacles, and permit you to install 3 prong receptacles in place of the two prong outlets on that circuit. Be sure to install the included stickers which say "no equipment ground available, GFCI protected."
jrclen is offline   Reply With Quote
Old 04-08-2008, 07:24 PM   #4
joed's Avatar
You are correct about using two prong or leaving alone. I neglected to mention the two prong option since the main reason most people want to replace these receptacles is get three prong receptacles.
Old 04-08-2008, 08:48 PM   #5
electrician
Yeah Right! Do people actually let you stick those ugly things on their cover plates
Silk is offline   Reply With Quote
Old 04-08-2008, 11:28 PM   #6
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Why would you want to put it on the cover plate?
Old 04-09-2008, 07:30 AM   #7
electrician
Where would you put it?
Old 04-09-2008, 11:53 AM   #8
jrclen's Avatar
Rewards Points: 514
I do. It's required by code.
Freezer tripping GFCI davidclements Appliances 58 07-03-2015 06:46 AM
Wiring in New Addition? sandyman720 Electrical 6 11-27-2011 04:34 PM
20 Amp Breaker tripping with GFCI panhandlion Electrical 7 12-12-2007 09:59 PM
GFCI questions 5circles Electrical 4 11-05-2007 09:24 PM
gfci receptacles rjr Electrical 2 05-02-2007 08:16 PM
