Gfci Receptacle Not Working - Electrical - DIY Chatroom Home Improvement Forum
Old 03-18-2008, 11:11 AM   #1
gfci receptacle not working
I have a gfci receptacle in my upstairs bathroom that controls both of the bathrooms. The gfci's test button seems like it is stuck and won't reset. I tried to reset the main gfci in the garage and also tried to reset the breaker but still the button is stuck and the electricity in both bathrooms are down. Do I need to replace the gfci or is there another method to solve this problem?
peterkim is offline   Reply With Quote
Old 03-18-2008, 01:56 PM   #2
Ok so the electricity in the bathrooms is still off?
When you reset the breaker, does it reset or does it trip again?
How is the Garage GFCI tied in with the bathroom GFCI? If the garage trips do both bathrooms go dead?
There are a few unanswered questions here, but a GFCI will not reset unless it has line voltage, if it does have line voltage it is probably defective. If you don't feel comfortable testing for live voltage on a circuit or have some experience tracing circuits you may want to call a electrician.
sparky120/240 is offline   Reply With Quote
Old 03-18-2008, 07:12 PM   #3
You need to pull it out and test voltage on the line side.
220/221 is offline   Reply With Quote
Questions About Changing GFCI receptacle to a normal three pronged outlet LYTTONJ Electrical 11 05-04-2011 02:23 PM
GFCI receptacle gets tripped by hallway light proofer Electrical 10 03-17-2008 07:29 PM
Bathroom Remodel GFCI Receptacle Lilshaving Electrical 4 02-24-2008 10:07 AM
Electric receptacle in lamp post and flood light not working th31 Electrical 7 12-13-2007 07:46 AM
GFCI replaced and not working Pullerwife Electrical 8 10-16-2007 12:50 PM
