GFCI Receptacle - Electrical - DIY Chatroom Home Improvement Forum
Old 04-25-2012, 01:12 PM   #1
GFCI Receptacle
Can an outside receptacle be protected by a GFCI on the inside of my garage or must the recep. outside be a GFCI aslo?
MisterSteve is offline   Reply With Quote
Old 04-25-2012, 01:39 PM   #2
Rewards Points: 2,512
Receptacle outside can get its power from the LOAD side of your GFCI which is inside garage
hammerlane is offline   Reply With Quote
Old 04-25-2012, 04:15 PM   #3
Too Short? Cut it Again!
Remember when placing the GCFI that it protects itself and all in front of it in the circuit.
Lost a friend years ago who trusted GCFI house wiring and could not let go of his concrete wet saw. I am a big believer in investing in at least a basic portable GCFI for use with outdoor power tools, extension cords and so forth. They used to be expensive but are not anymore. Cheap insurance.
Old 04-25-2012, 04:48 PM   #4
I=E/R
a7ecorsair's Avatar
It protects itself and all after it, not what is in front.
Why would you trust a portable cord any more than a properly wired GFI receptacle or are you referring to using this at an unknown receptacle?
a7ecorsair is offline   Reply With Quote
Old 04-25-2012, 04:56 PM   #5
Ooops. Wrong wording. Typed to fast. Glad you caught it!
I trust the portable because I do not know if the home I am working on has a properly wired GCFI protecting the circuit I am tapping so yes it is an unknown situation.
Old 04-26-2012, 11:42 AM   #6
OK, So a regular receptacle can be used on the exterior of my garage downstream from a GFCI receptacle on the interior of my garage and will be GFCI protected and will not violate code?
Old 04-26-2012, 12:00 PM   #7
Licensed electrician
Rewards Points: 1,038
You just need the GFI protection. It does not matter where in the circuit it comes from. Portable GFI devices would not count towards this. It would need to be a GFI breaker or receptacle.
Adding GFCI receptacle outdoors Dale Gribble Electrical 2 03-21-2012 02:18 PM
Replacing receptacle with GFCI wiring problem braden Electrical 8 04-06-2011 09:32 AM
GFCI receptacle on GFCI circuit breaker thewoodguy Electrical 3 12-02-2010 02:37 PM
GFCI receptacle gets tripped by hallway light proofer Electrical 10 03-17-2008 08:29 PM
Bathroom Remodel GFCI Receptacle Lilshaving Electrical 4 02-24-2008 11:07 AM
