GFCI Question Regarding Hardwired Vs Plug-in Disposal - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-13-2012, 10:47 AM   #16
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
The plumber cabling out the sink drain from under the cabinet might appreciate that outlet being gfi protected
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 04-13-2012, 11:03 AM   #17
Electrical Contractor
jbfan's Avatar
Rewards Points: 378
His machine and cord should have gfci protection built in anyway!
jbfan is online now   Reply With Quote
Old 04-13-2012, 11:19 AM   #18
plummen's Avatar
Most smaller machines drill motor/cable drum dont have gfi built into cord ,bigger machines usually do.
Old 04-13-2012, 01:27 PM   #19
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,942
WHY???
That receptacle is most likely switched, and the counter receptacles would most likely be GFI if he wants them. Besides, the counter receptacles are MUCH easier to get to.
Old 04-13-2012, 01:41 PM   #20
DIYer
Rewards Points: 262
Never thought I'd create such a discussion.
mystic_cobra is offline   Reply With Quote
The Following User Says Thank You to mystic_cobra For This Useful Post:
electures (04-13-2012)
Old 04-13-2012, 02:50 PM   #21
plummen's Avatar
Originally Posted by Speedy Petey View Post
WHY???
When youre flat on your back under a sink its a lot easier to use an outlet right there where youre working rather than trying to run it down over/around everything when youre in a cramped space.
Thats the great thing about a switched plug,you can unplug the disposal and plug in a snake and still have power.
So do you install a gfi in the top cabinet to plug a built in microwave into?
Old 04-13-2012, 03:01 PM   #22
jbfan's Avatar
Rewards Points: 378
Everyone here loves a great debate!
The Following User Says Thank You to jbfan For This Useful Post:
gregzoll (04-13-2012)
Old 04-13-2012, 03:17 PM   #23
plummen's Avatar
Well Im looking at it from the point of view of somebody who has spent time under more sinks than hed like to remember over the years
Old 04-13-2012, 04:57 PM   #24
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Originally Posted by gregzoll View Post
May want to go back and read what I posted, then go and read the NEC regarding Where they are and are not required in a Kitchen. I do believe that I covered that under the word "Counter tops". When have you seen a gfci outlet or protected outlet on a baseboard in a Kitchen?
Point taken and accepted.
But...could someone explain why your washer/dryer 120V recept would need to be GFI protected if it is within 6' of the sink, but if the fridge outlet is within 6', GFI protection is not needed?
Old 04-13-2012, 06:26 PM   #25
Rewards Points: 6,652
Because it is usually in a space that is unfinished (ie basement or garage), and/or also has a deep sink next to it.
Here is the 2011 NEC take on it:
(F) Laundry Areas. In dwelling units, at least one recep-
tacle outlet shall be installed for the laundry.
Exception No. 1: In a dwelling unit that is an apartment or
living area in a multifamily building where laundry facilities
are provided on the premises and are available to all build-
ing occupants, a laundry receptacle shall not be required.
Exception No. 2: In other than one-family dwellings where
laundry facilities are not to be installed or permitted, a
A laundry receptacle outlet(s) is supplied by a 20-ampere
branch circuit. This circuit can have no other outlets. See
210.11(C)(2) for further information.
Recognizing that sinks in kitchens are not the only location
where a ground-fault shock hazard exists, this requirement
covers all other sinks in a dwelling. This requirement does
not limit the GFCI requirement to only receptacles serving
countertop surfaces; rather, it covers all 125-volt, 15- and
20-ampere receptacles that are within 6 ft of any point along
the outside edge of the sink. Many appliances used in these
locations are ungrounded, and the presence of water and
grounded surfaces contributes to a hazardous environment.
As illustrated in Exhibit 210.14, any 125-volt, 15- and
20-ampere receptacle installed within 6 ft of a sink located
in other than a kitchen is required to be GFCI protected.
GFCI Question wildjuanpablo Electrical 7 11-28-2011 07:54 PM
GFCI Question daveplot Electrical 11 06-10-2011 09:23 PM
Undercabinet Surface Mounted Box for Disposal Plug xd11 Electrical 5 12-04-2010 08:40 AM
wiring switch to gfci plug wendl Electrical 5 04-05-2010 09:02 PM
Disposal GFCI DaveHembree Electrical 3 10-23-2007 01:30 PM
