Old 04-08-2012, 02:25 PM   #1
Question
GFCI question regarding hardwired vs plug-in disposal
My old garbage disposal was hardwired to its own 15A non-GFCI circuit using a cable coming straight out the wall. After renovation the entire kitchen, we decided to switch to a countertop button with the air/vacuum type switch. Now I'm using a plug in cord and a std outlet/receptacle that I installed under the sink. Should this be a GFCI outlet?
1965 house, Northern VA
thanks
Jimmy
mystic_cobra is offline   Reply With Quote
Old 04-08-2012, 02:27 PM   #2
Average Joe/ex-Navy IC3
gregzoll's Avatar
It is up to your local regulations to decide that or not. If you want to feel safer, go ahead and install a gfci outlet under there.
: Now listen, Cadet. I've got a job for you. See this button?
: Don't touch it! It's the History Eraser button, you fool!
: So what'll happen?
: That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
gregzoll is online now   Reply With Quote
Old 04-08-2012, 02:32 PM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Regardless of how it is wired, it does not need a GFI.
Put one in if you like, but it is not required.
The Following User Says Thank You to Speedy Petey For This Useful Post:
k_buz (04-12-2012)
Old 04-12-2012, 09:48 PM   #4
Lic Electrical Inspector
electures's Avatar
GFI is not required.
All responses based on the 2011 NEC.
If you live in New Jersey click
. All other states click
Please check with local, county and state officials as laws may vary.
Sizing motors
. Online motor calculator
. Online calculators
electures is offline   Reply With Quote
Old 04-12-2012, 10:33 PM   #5
Thanks guys. I guess it makes sense. Not much chance of a garbage disposal falling into a sink full of water while someone is washing dishes.
Old 04-12-2012, 10:38 PM   #6
Licensed Electrician
k_buz's Avatar
Actually, it doesn't make much sense at all...but per the code, you don't need to install a GFI under a sink.
Old 04-12-2012, 10:46 PM   #7
I guess you could have an internal short inside the disposal or something, right?
If you guys were installing one of these in your own kitchen would you install a GFCI?
Old 04-12-2012, 10:47 PM   #8
gregzoll's Avatar
Not, due to not required either on the Disposal, Dish washer, Trash Compactor, Stove, Fridge. Only needed on the countertops.
Old 04-12-2012, 10:48 PM   #9
k_buz's Avatar
No I wouldn't. I just don't understand the thinking behind some of the codes, and this is one.
The Following User Says Thank You to k_buz For This Useful Post:
plummen (04-13-2012)
Old 04-12-2012, 10:50 PM   #10
k_buz's Avatar
That's not true. If an outlet is within 6' of a sink, it needs to be GFI protected. But the disposal and dishwasher doesn't count because they consider the outlet to be protected by a physical barrier...which is either the countertop, or the sink itself...while ignoring all the plumbing under the sink.
Old 04-13-2012, 06:37 AM   #11
I don't understand the logic behind this.
How is this ANY different from having wiring or device boxes in stud bays with plumbing? Or having a panel next to a slop sink? Or having a hard wired septic pump?
NONE of which are inherently unsafe, nor would benefit from GFI protection.
Old 04-13-2012, 06:39 AM   #12
GFI protection has nothing to do with short circuit protection. That is what the circuit breaker is for.
Contrary to what many/most people think, a GFI is NOT a circuit breaker.
I didn't in mine, and don't for customers either.
Old 04-13-2012, 08:17 AM   #13
gregzoll's Avatar
May want to go back and read what I posted, then go and read the NEC regarding Where they are and are not required in a Kitchen. I do believe that I covered that under the word "Counter tops". When have you seen a gfci outlet or protected outlet on a baseboard in a Kitchen?
The Following User Says Thank You to gregzoll For This Useful Post:
k_buz (04-13-2012)
Old 04-13-2012, 09:12 AM   #14
electures's Avatar
No. Because it is not required.
Sizing motors
The Following User Says Thank You to electures For This Useful Post:
HIVOLT (04-13-2012)
Old 04-13-2012, 11:04 AM   #15
i thought the 6' sink rule only applied to sinks NOT in a kitchen. by default, all the receptacles serving countertops in a kitchen need to be GFCI so anything by a kitchen sink would be GFCI anyway. the receptacle under the sink for a disposal is not installed to serve countertop surfaces and thus does not need to be GFCI protected.
but this brings up an interesting question: say i have a wet-bar sink with a disposal and a receptacle under the sink to serve that disposal. would that need to be GFCI? it would be within 6' of the sink but 'protected' by the countertop, cabinet door, etc. i mean, if the wet-bar was in the middle of a room with a wall behind it, a receptacle on the other side of the wall wouldn't need to be GFCI. i'm thinking the disposal receptacle would not need to be GFCI.
itsnotrequired is offline   Reply With Quote
GFCI Question wildjuanpablo Electrical 7 11-28-2011 08:54 PM
GFCI Question daveplot Electrical 11 06-10-2011 10:23 PM
Undercabinet Surface Mounted Box for Disposal Plug xd11 Electrical 5 12-04-2010 09:40 AM
wiring switch to gfci plug wendl Electrical 5 04-05-2010 10:02 PM
Disposal GFCI DaveHembree Electrical 3 10-23-2007 02:30 PM
