Old 11-22-2008, 06:51 PM   #1
GFCI question
I have a bathroom outlet on its own circuit. The outlet is a GFCI receptacle but the circuit breaker in the panel is also a GFCI breaker. It's an odd size breaker in width and I'd like to replace it with a normal 20amp breaker. Do I really need a GFCI breaker if the outlet is also GFCI protected??
jadrma is offline   Reply With Quote
Old 11-22-2008, 08:14 PM   #2
Electrical Contractor
kbsparky's Avatar
GFCI question
Nope. You don't need redundant Ground fault protection, and can use a standard breaker if the device is a GFCI type. Make sure that there are no other devices also connected to that breaker before swapping it out for a non-GFI one (outside outlets, garage, etc).
GFCI Question Nealndar Electrical 2 09-13-2008 06:15 PM
GFCI Question dankreboot Electrical 5 08-06-2008 09:33 PM
GFCI in detached garage question WShawn Electrical 2 08-02-2008 04:27 PM
GFCI Question Mdbuilder Electrical 6 06-19-2008 04:15 PM
Hot Tub GFCI Grounding Question kearnak1420 Electrical 3 04-30-2008 06:48 PM
