Gfci Question - Electrical - DIY Chatroom Home Improvement Forum
Old 11-25-2011, 10:26 AM   #1
Gfci question
I have a kitchen outlet that needs a gfci receptacle the regular outlet has 1 hot wire and 3 common (white) wires connected to it. Is the proper way to connect white wires by pig tailing to the line terminal on gfci silver terminal?
tommyd78 is offline   Reply With Quote
Old 11-25-2011, 11:03 AM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 650
Something is not right with that set up.
Can you take a pic so we can better understand what might be there.
Old 11-25-2011, 02:11 PM   #3
I'm not able to take a picture now it is the electrical outlet on counter we have always had the coffee pot plugged into. As long as I have lived there 5 years, it has been that way no breaker trips or anything. Next to it is a switch for garbage disposal, it is not connected to the outlet. The 3 common wires go out the box somewhere. Selling this house and expect they will want gfci's there.
Old 11-25-2011, 03:45 PM   #4
Master Electrician
Rewards Points: 3,966
The same wires connectd to the existing receptacle should be connected to the GFCI load terminals if it is a dead end receptacle(no other receps downstream).
brric is online now   Reply With Quote
Old 11-25-2011, 07:39 PM   #5
gfci
How can I tell if it is a dead end terminal?
Old 11-25-2011, 07:49 PM   #6
Rewards Points: 1,548
You mean GFCI line terminals.
THe most obvious sign of a dead end is having only one cable or set of wires coming into the box; no wires to continue on (daisy chain) to more receptacles downstream.
It will always work if you connect up the GFCI the same way the previous receptacle was connected up.
Optional, in some cases if there is a receptacle(s) downstream, they can receive GFCI protection from this one GFCI receptacle unit if the wires (both hot and neutral) for it (them) are connected to this GFCI load terminals.
It can be a little complicated figuring out which is the incoming power and which is the wiring continuing downstream to other receptacles. A voltmeter would help.
Sometimes (again needing analysis, for example where multiwire branch circuits are found) it is not practical to use the load terminals and continue GFCI protection from this GFCI unit to additional receptacles downstream. Installing additional GFCI receptacles at other locations desiring GFCI protection will work in these cases.
The Following User Says Thank You to AllanJ For This Useful Post:
brric (11-25-2011)
Old 11-25-2011, 07:52 PM   #7
Master Electrician
It will work if you connect up the GFCI the same way the previous receptacle was connected up.
Yes, I did mean line terminals, thanks.
Old 11-25-2011, 07:56 PM   #8
Gfci
I will connect it the way they are in the box currently to the line terminals on GfCI and test with a lamp and if its right power will go off to lamp when I press test button and if it doesn't go off I need to use the load terminals?
Old 11-26-2011, 02:48 PM   #9
Rewards Points: 115
load terminals are for downstream loads if any. use only line terminals if no other recpts. connected. also sounds like a lot of shared neutrals in this box. where do they go?
pokey is offline   Reply With Quote
Old 11-27-2011, 10:11 AM   #10
Don't know , i have never had a problem with the set up will connect like it says to do here I appreciate the replies. I will see how i do.
GFCI Conduit question llenod Electrical 3 04-06-2011 12:09 PM
Whirlpool GFCI circuit info conflict. 3detailer Electrical 29 05-17-2010 09:12 AM
GFCI Stumper ksqrdks Electrical 2 04-03-2010 06:24 AM
GFCI question. Please Help. the banana k1ng Electrical 4 10-09-2009 07:35 PM
GFCI Question Mdbuilder Electrical 6 06-19-2008 03:15 PM
