GFCI Protection Of Bathroom - Electrical - DIY Chatroom Home Improvement Forum
Old 09-10-2012, 03:49 PM   #1
GFCI protection of bathroom
I have a bathroom circuit I need to GFCI protect.
Power comes from the panel to a receptacle just outside the bathroom. From the receptacle to two switch boxes - one which controls a light outside the bathroom door - and one to a switch box in the bathroom. From the switch box in the bathroom to a light, a fan, and a receptacle beside the sink.
The switch in the bathroom is within 1 m of the shower stall so needs class A GFCI protection and the receptacle beside the sink needs GFCI protection.
Two questions:
1. Is it allowed to protect the whole circuit by replacing the first receptacle with a GFCI receptacle and connecting lines an loads appropriately?
2. This first receptacle supplied two other enclosures. Can I bring power in, tie it into the line screws, and pigtail the two loads before connecting to the load screws?
The box is 18 cu.
A $20 GFCI receptacle is much more attractive than an $85 GFCI breaker
zubor is offline   Reply With Quote
Old 09-10-2012, 05:57 PM   #2
Resi EC
Rewards Points: 252
The switch, outside the shower does not need protection, unless it switches a fan in the shower. The receptacle does need to be GFCI
Gac66610 is offline   Reply With Quote
Old 09-10-2012, 07:12 PM   #3
kevinp22's Avatar
didnt notice Canada location. post deleted
kevinp22 is offline   Reply With Quote
Old 09-10-2012, 07:31 PM   #4
Resi EC
Rewards Points: 252
Originally Posted by kevinp22 View Post
Code for renov/new requires bath only loads on bath rec circuits, but i assume just replacing a device wouldnt trigger requirements to update???
Local rules vary, I would assume no ... but you know what they say about assuming, check with local building division.
Old 09-10-2012, 08:29 PM   #5
Electrical Contractor
jbfan's Avatar
Rewards Points: 224
By him using 1 m of the shower makes me think he may be in Canada, so US rules would not apply.
Old 09-10-2012, 08:48 PM   #6
Yepp. I'm in Canada. According to the CEC, all switches within 1 m of a shower stall must be GFCI class A protected.
From ESA FAQ:
Question
Is a separate circuit required to supply a receptacle in a bathroom?
Answer
The code does not require a separate circuit for bathroom receptacles. Bathroom receptacles can be supplied by a general purpose circuit that supplies other general purpose receptacle and lighting outlets. Multiple bath and washrooms are permitted to be supplied by the same circuit.
Old 09-10-2012, 08:55 PM   #7
Resi EC
Rewards Points: 252
ummmm oops, didn't even notice
Bathroom lights shared with 20 amp GFCI Polecatt2 Electrical 4 03-20-2011 11:09 PM
GFCI in the bathroom trouble canyonbc Electrical 7 01-26-2010 03:36 AM
Bathroom lighting on GFCI? TReally Electrical 7 10-22-2009 12:05 AM
GFCI Outlet installation in bathroom... budde97 Electrical 4 02-11-2007 01:22 AM
GFCI protection for Shop/Garage Sub-Panel porterpearl Electrical 3 01-06-2006 04:33 PM
