GFCI Protected Outlets - Electrical - DIY Chatroom Home Improvement Forum
Old 08-06-2011, 05:53 PM   #1
Murdy's Avatar
Rewards Points: 37
GFCI protected outlets
Is there a limit to the number of outlets I can protect with one GFCI recepticle? I'm running a 20 amp circuit to serve the counter tops. Given the layout, I need 3 additional outlets. I'd also like to stick one behind the stove off the end of the cabinets (it would be convenient given layout of our house) for a total of 5 outlets. Is that too many?
I also am installing 2 small accent lights that it would be way easier to pull off this circuit rather than running cable from the lighting circuit. Is this advisable?
Thanks for any help.
Murdy is offline   Reply With Quote
Old 08-06-2011, 06:35 PM   #2
Licensed electrician
Rewards Points: 996
In the US under the NEC you cannot add the lighting to the small appliance branch circuit. You should also have two 20 amp small appliance branch circuits. There is no limit to the number of downstream receptacles.
Old 08-06-2011, 08:23 PM   #3
Full time DIY
Where are you? In Ontario the maximum number of countertop receptacles on a 20A kitchen countertop circuit is two.
G-Mo is offline   Reply With Quote
Old 08-07-2011, 12:06 AM   #4
Murdy's Avatar
Rewards Points: 37
Thanks for the advice. I'm in Illinois, and I know I'm under the NEC.
GFCI Outlets in Series allbymyself Electrical 6 01-25-2011 12:52 AM
GFCI breakers equivalent to GFCI outlets? Any code pitfalls? TomServo Electrical 27 02-04-2010 11:59 PM
Replacing kitch outlets to GFCI jhubert Electrical 7 11-16-2009 08:23 PM
downstream of GFCI outlets amakarevic Electrical 11 12-25-2008 02:13 PM
two GFCI outlets at bath vanity Hickory Electrical 6 12-18-2005 10:31 AM
