Gfci Problem - Electrical - DIY Chatroom Home Improvement Forum
Old 11-14-2006, 09:01 PM   #1
gfci problem
I did some work in my kitchen today and thought I might have hit a line with a screw. I hooked a light back up that I had disconnected and it wouldn't work. It was getting power but the neutral was hot also. This light is getting power from a gfci outlet. I tested the outlet and the neutral wires were hot too. Anything plugged into it didn't work. This is when I though I hit a wire and shorted something. I thoroughly check everything and didn't find any hit wires. I then checked the gfci outlet and it turned out that was it. Is this common for them to go like this? When I plugged a radio into it for a test I got a slight shock. Strange.
farrington135 is offline   Reply With Quote
Old 11-15-2006, 06:57 PM   #2
how did you test it?
redline is offline   Reply With Quote
New GFCI Breaker Tripping w/ 3-way Flourescents BigJimmy Electrical 8 12-29-2008 02:29 PM
Kitchen outlet breaker simma Electrical 3 02-28-2007 05:50 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 01:51 PM
GFCI protection for Shop/Garage Sub-Panel porterpearl Electrical 3 01-06-2006 03:33 PM
GFCI problem Unregistered Electrical 3 02-08-2004 09:41 PM
