Gfci Problem.. - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 04-01-2014, 05:57 PM   #31
dmxtothemax's Avatar
Rewards Points: 5,180
Originally Posted by stickboy1375 View Post
Why should the lighting be separate from receptacles?
In Australia it is standard practice !
Lights on one circuit
And power on another !
I think its a good idea !
Cause if you blow a breaker you dont plunge the room into darkness,
a good safety idea.
dmxtothemax is offline   Reply With Quote
Old 04-01-2014, 06:37 PM   #32
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
a good safety idea.
And what happens if the lighting breaker trips?
The Following User Says Thank You to k_buz For This Useful Post:
gregzoll (04-01-2014)
Old 04-01-2014, 07:08 PM   #33
JOATMON
ddawg16's Avatar
Rewards Points: 1,454
The wall powered floor or desk lamp still works.....and if the layout was done right...the adjacent room works....
It gets a bit more complicated when there is a power outage....
At the end of the day....do what you want.....
Personally, I like the fact that I can turn off the power to outlets in a room and still have lights....or turn off the lighting ckt and still have power to the outlets for a floor lamp.
The Following User Says Thank You to ddawg16 For This Useful Post:
gregzoll (04-02-2014)
Old 04-01-2014, 08:11 PM   #34
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Seperating lighting from receptacles makes no sense, you can try to justify it anyway you want, but in the end the result is the same.....
The Following User Says Thank You to stickboy1375 For This Useful Post:
Stubbie (04-02-2014)
Old 04-01-2014, 10:48 PM   #35
Rewards Points: 6,652
I am the same way ddawg. Hate having a place, that the lights are tied into the outlets. Wait, scratch that. My Living Room is still on the same circuit as the outlets. One of those items that is still on my to-do list.
Old 04-01-2014, 11:42 PM   #36
JOATMON
ddawg16's Avatar
Must be an Eastern thing....set in your ways....regardless of any reasons your given....
One could say....how do you justify putting them on the same ckt?
Old 04-02-2014, 12:58 AM   #37
Rewards Points: 29
When I layout a room for electrical, I mix and match....usually several lights and a few receptacles per circuit. My breakers never trip so it's moot but that way if they do, I still have some lighting that works.
liljohnny is offline   Reply With Quote
Old 04-02-2014, 04:45 AM   #38
E2 Electrician
Originally Posted by ddawg16
Must be an Eastern thing....set in your ways....regardless of any reasons your given.... One could say....how do you justify putting them on the same ckt?
I've been doing this for a very long time, and never once have I gone into a house, turned off a circuit breaker and said "thank god a genius wired the light on a different circuit" it just doesn't happen..... With that said, DIY people generally recreate the wheel when wiring and over kill everything because they really just lack the knowledge and real world scenarios.
The Following 3 Users Say Thank You to stickboy1375 For This Useful Post:
k_buz (04-02-2014), mm11 (04-02-2014), Stubbie (04-02-2014)
Old 04-02-2014, 08:51 AM   #39
joed's Avatar
Rewards Points: 12,440
How many times are you guys tripping breakers that lights going off is a big concern? I can't remember the last time I tripped a breaker. You have bigger issues than lights and receptacles sharing circuits if you are tripping breakers enough that this a big concern.
The Following 3 Users Say Thank You to joed For This Useful Post:
gregzoll (04-02-2014), Jim Port (04-02-2014), Stubbie (04-02-2014)
Old 04-02-2014, 09:38 AM   #40
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Ddawg ... I'm assuming here this is because you are anticipating an electrical problem someday and you want the convenience of light or power close by ?? Otherwise why would you want to do that on a regular enough basis to warrant a wiring layout like that?
The discussion here isn't about how you want to wire your personal home but about how it makes any real and applicable difference any where else..
convenience is not a good enough reason to justify the extra cost in labor and materials for a problem that would be very rare in a quality wired home where that is not done.
BTW .. I'll wire a home with lights and receptacles on separated circuits where possible as I comply with NEC codes as long as my name appears on the front of a big enough check ...
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 04-02-2014, 02:50 PM   #41
JOATMON
ddawg16's Avatar
And your doing most of your work during the day.....when its still light outside.
I don't anticipate tripping breakers...but I like being able to turn off outlet power and still have lights.
And...I find it a lot easier to wire lights with 14/2 vs using 12/2...
Unless of course your doing your outlets on 15a ckts....
Do what ever you want....your going to do what is quickest and easiest to code.....but on my house...I'll do it my way....and based on all the houses in my area....they were doing it that way 60 years ago.
One last thing.....what is wrong with the way I'm doing it? You have never been able to answer that....nor do I think you can answer it....
2 Similar GFCI, but one tests open ground crescere Electrical 40 08-28-2012 09:19 PM
GFCI wiring for a jetted bathtub couchpotato Electrical 13 03-20-2012 11:26 AM
GFCI problem Captflx Electrical 3 02-27-2011 05:21 PM
GFCI problem Unregistered Electrical 3 02-08-2004 09:41 PM
