Gfci Problem.. - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-30-2014, 11:14 PM   #16
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Originally Posted by ddawg16
And the reason why is?
Why should the lighting be separate from receptacles?
Old 03-30-2014, 11:22 PM   #17
JOATMON
ddawg16's Avatar
Rewards Points: 1,122
A 'few' reasons....
Lighting ckts are typically 15a
Receptacles are typically on 20a ckts;
And....it sort of sucks when a receptacle trips the breaker and the lights go out.
In fact, in my house, the lights are wired such that no breaker feeds two adjacent rooms....i.e., if the breaker trips for one room, the lights in the other rooms are not affected.....(power outages excluded)
So....why was my earlier statement 'ignorant'
I explained my reasons.....can you do the same?
ddawg16 is online now   Reply With Quote
The Following User Says Thank You to ddawg16 For This Useful Post:
gregzoll (03-30-2014)
Old 03-30-2014, 11:46 PM   #18
Rewards Points: 29
Receptacles are on 20A circuits, since when, I thought that only applied to certain circuits like the kitchen???
liljohnny is offline   Reply With Quote
Old 03-31-2014, 12:06 AM   #19
iminaquagmire's Avatar
Rewards Points: 338
I'd say the vast majority of receptacles in residential are on 15A circuits with lighting. I understand ddawg's point, but you shouldn't be planning on having a circuit trip. The circuit should be designed so that it doesn't trip in the first place. That's designing a whole layout based on a hopefully rare occurrence that if it does happen at all is an inconvenience, not a life safety thing.
iminaquagmire is offline   Reply With Quote
Old 03-31-2014, 12:18 AM   #20
Rewards Points: 29
^^^ My thinking exactly!
Old 03-31-2014, 12:18 AM   #21
dmxtothemax's Avatar
Rewards Points: 5,102
Originally Posted by Albertc View Post
I have a gfci in the laundry room. Everything was fine this morning, but this afternoon I went into laundry room and fluorescent light doesn't work. I push reset button on gfci and doesn't work. I go to main panel and find the breaker for the laundry/gfci circuit. Breaker is tripped. I reset breaker in panel and go back to the laundry room. Gfci will now reset. When I try turning on the light, the light flashes on and immediately goes off. Gfci will not reset. I go back to panel and breaker is tripped again.
What does this mean. Does this mean that I need to replace the gfci or is something else wrong?
Post Extras:
More likely something else is wrong !
Most likely a faulty light fitting/ballast.
dmxtothemax is online now   Reply With Quote
Old 03-31-2014, 01:45 AM   #22
Rewards Points: 6,652
No. It can apply to outside, Basement, Garage/Carports, Laundry areas, Kitchen & dining, Food Pantry areas.
There is more then just what I stated, that 20 amp circuits can be used in. As for the outlets, it is your choice to use them on the 20 amp circuits. Majority of the time in residential applications, you will only find 15 amp outlets, that of course are rated at 20 amp pass through.
Old 03-31-2014, 09:33 AM   #23
joed's Avatar
Rewards Points: 11,998
The test lamp in the receptacle pretty much eliminates the switched lights as the cause.
Having no other obvious solution since the GFCI is also tripping, I say change the GFCI.
If that doesn't work then change the breaker. You could try just swapping the wire with another 15 amp breaker in the panel as a test.
The Following User Says Thank You to joed For This Useful Post:
47_47 (03-31-2014)
Old 03-31-2014, 09:36 AM   #24
I finally figured it out! The push in wires on one side of the gfci were loose. Tightened these up and everything works. Thanks to all who tried to help.
Albertc is offline   Reply With Quote
The Following User Says Thank You to Albertc For This Useful Post:
47_47 (03-31-2014)
Old 03-31-2014, 11:16 AM   #25
JOATMON
ddawg16's Avatar
Back stabbed.....something else I don't do....
Old 03-31-2014, 11:17 AM   #26
JOATMON
ddawg16's Avatar
My house was built in the 50's.....none of the receptacles were on lighting ckts....
20a for Receptacles....15a for lighting.
I'm still waiting to find out why it's 'ignorant'....
gregzoll (03-31-2014)
Old 03-31-2014, 12:26 PM   #27
FIDO...
Rewards Points: 239
I can't speak for Stickboy, but here's my angle on the issue...
I agree that in my perfect dream home, I would have lights and oulets on separate 15 vs 20 circuits - I can definitely get behind the the plusses of doing that.
However, many existing homes are simply not wired that way (to include mine!), and it would be a pretty large-scale, invasive project to re-wire an exiting home to accomplish that goal. For most folks, such a thing isn't genuinely necessary, so it simply isn't practical or realistic to consider.
If a newbie DIYer (who doesn't know better) read your comment disparaging combo circuits, they may interpret it as something unsafe or truly wrong, and that isn't the case.
Again, I totally hear where you are coming from with the ideal of separate circuits, but I think -- for clarification purposes targeted at newbies -- it's important to note that there's nothing inherently wrong with a combo circuit setup.
Thanks, Chris
Chris130 is offline   Reply With Quote
Old 03-31-2014, 04:18 PM   #28
joed's Avatar
Not back stabbed in this, but back wired. Wires go under a plate that clamps down on them.
Old 03-31-2014, 04:48 PM   #29
GFCI outlets do not have the capability to be back stabbed.
Old 03-31-2014, 04:55 PM   #30
JOATMON
ddawg16's Avatar
Ok.....now that I think of it, I've never seen one that was back stabable....
2 Similar GFCI, but one tests open ground crescere Electrical 40 08-28-2012 10:19 PM
GFCI wiring for a jetted bathtub couchpotato Electrical 13 03-20-2012 12:26 PM
GFCI problem Captflx Electrical 3 02-27-2011 06:21 PM
GFCI problem Unregistered Electrical 3 02-08-2004 10:41 PM
