Gfci Problem.. - Electrical - DIY Chatroom Home Improvement Forum
Old 03-30-2014, 06:21 PM   #1
Gfci problem..
I have a gfci in the laundry room. Everything was fine this morning, but this afternoon I went into laundry room and fluorescent light doesn't work. I push reset button on gfci and doesn't work. I go to main panel and find the breaker for the laundry/gfci circuit. Breaker is tripped. I reset breaker in panel and go back to the laundry room. Gfci will now reset. When I try turning on the light, the light flashes on and immediately goes off. Gfci will not reset. I go back to panel and breaker is tripped again.
What does this mean. Does this mean that I need to replace the gfci or is something else wrong?
Post Extras:
Albertc is offline   Reply With Quote
Old 03-30-2014, 06:28 PM   #2
joed's Avatar
Rewards Points: 12,918
Change the the ballast or the whole fluorescent fixture. It sounds like the ballast has gone bad.
Old 03-30-2014, 06:34 PM   #3
Rewards Points: 6,652
The light is the culprit. If it is plugged into the outlet, unplug it and remove, until you can get a new fixture to replace that one.
Old 03-30-2014, 06:50 PM   #4
JOATMON
ddawg16's Avatar
Rewards Points: 1,826
The new version of GFCI's will not reset unless they have power to them.
Like the others said...bad light.
ddawg16 is online now   Reply With Quote
Old 03-30-2014, 06:56 PM   #5
More info. I actually have 3 floresent lights and one receptical on this 15 amp breaker. Two of the lights are on one switch an one light is on another switch.
The problem happens no matter which switch I turn on and I just tried plugging a lamp in the receptical after having reset the breaker and the gfci and when I turn the lam on, same thing light comes on for a split second and then goes off.
Thanks for any additional info.
Old 03-30-2014, 07:24 PM   #6
JOATMON
ddawg16's Avatar
A perfect example of why lights and outlets should not be on the same ckt.....
Old 03-30-2014, 07:37 PM   #7
Originally Posted by Albertc View Post
More info. I actually have 3 fluorescent lights and one receptical on this 15 amp breaker. Two of the lights are on one switch an one light is on another switch.
Why. We have already told you the problem. Quit testing and remove the light from the circuit. It should not have been on a GFCI to begin with.
Who ever did the work, probably did not know that. Is this place your home, or a rental that you live in? If you own. Was this a flip?
Old 03-30-2014, 07:39 PM   #8
Tell me about it. When I had the power off to the Kitchen, while doing some work on the electrical for the remodel. The wife kept asking why she could not reset the GFCI outlet on one of the branch circuits.
This was after I told her that I was turning power off to that area.
Old 03-30-2014, 07:42 PM   #9
JOATMON
ddawg16's Avatar
Let me guess....she thought they were 'wireless' outlets?
The Following 2 Users Say Thank You to ddawg16 For This Useful Post:
curtd (03-31-2014), gregzoll (03-30-2014)
Old 03-30-2014, 07:43 PM   #10
Tell me about it. Our house had originally four circuits. If you cut the house in four parts, that was how it was set up. They had lights in the basement at each junction box.
You find out real quick when you start splitting old circuits apart, with pulling new wire, how many circuit breakers you really need.
My next door neighbor's garage is set up that way. Incoming from the fuse panel to a GFCI, which feeds all outlets & lights. Best thing about this, is that it is NM feeding the garage, with a splice taped just past her walkway.
I think that the same person that did my run to our garage when we moved in. Did both neighbors on both sides of us.
I hate that our city does not inspect homes for improper wiring. But then again those of us that do know how to do this work. Really would like to find them and slap the idiots around.
Old 03-30-2014, 08:02 PM   #11
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
That's just ignorant to even say.
Old 03-30-2014, 08:25 PM   #12
They are when they were sitting in the bucket, that I was using to put parts in, while I was working in the Kitchen.
It is amazing how this new technology works.
Old 03-30-2014, 08:50 PM   #13
joed's Avatar
Is the breaker a GFCI breaker?
Old 03-30-2014, 09:36 PM   #14
No it's not a gfci breaker.
Old 03-30-2014, 10:03 PM   #15
JOATMON
ddawg16's Avatar
And the reason why is?
The Following User Says Thank You to ddawg16 For This Useful Post:
2 Similar GFCI, but one tests open ground crescere Electrical 40 08-28-2012 09:19 PM
GFCI wiring for a jetted bathtub couchpotato Electrical 13 03-20-2012 11:26 AM
GFCI problem Captflx Electrical 3 02-27-2011 05:21 PM
GFCI problem Unregistered Electrical 3 02-08-2004 09:41 PM
