Gfci Pops - Electrical - DIY Chatroom Home Improvement Forum
Old 06-19-2011, 07:58 AM   #1
Gfci pops
I installed a bathroom exhuast fan,I thought it would be a good idea to install a gfci with the on/off switch ,the fan works ok but when you turn off the fan the gfci pops ,my source of power for the bathroom fan is the attic fan
corbyway is offline   Reply With Quote
Old 06-19-2011, 09:13 AM   #2
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
IS the fan protected by the GFI? If so, it not required to be GFI protected unless it is mounted over the shower or tub. Could be caused by the motor. Could be defective GFI. Check wiring.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
GFCI pops when Washer is plugged in lisaz Electrical 74 09-04-2013 06:57 AM
Swamp cooler pops GFCI broken68 Electrical 38 09-28-2010 08:00 PM
20 amp GFCI breaker pops when pool pump is turned on. jagrunner Electrical 11 03-19-2010 04:31 PM
new gfci on new circuit pops rtoni Electrical 39 11-15-2008 10:18 AM
GFCI Question Mdbuilder Electrical 6 06-19-2008 03:15 PM
