Old 08-31-2012, 01:46 PM   #1
GFCI overload
What happens if I have a 15A GFCI receptacle and I connect a 2000W heater (16.6A) to it?
jackwashere is offline   Reply With Quote
Old 08-31-2012, 01:51 PM   #2
Licensed electrician
GFCI overload
GFIs do not trip due to overload. A 15 amp GFI can be on a 20 amp circuit.
What size is the circuit feeding the GFI?
Fifteen amps is 1800 watts. A breaker can hold 125% for over an hour.
Old 08-31-2012, 01:55 PM   #3
GFCI overload
GFI's do not protect againt over loads, breakers or fuses do that.
Why would you even think about plugging that heater in that circut knowing it's going to case an overload.
Not a great plan unless it's 12-2 wire and a 20 amp breaker.
Old 08-31-2012, 01:58 PM   #4
Electrical Contractor
GFCI overload
The 2000 watt heater will have a 20 amp plug and would not fit a 15 amp gfci.
Yes I am a Pirate, 200 years too late. "Jimmy Buffett"
Old 08-31-2012, 02:06 PM   #5
GFCI overload
I have a picture that shows it can be done if you try hard enough.
Old 08-31-2012, 02:09 PM   #6
E2 Electrician
stickboy1375's Avatar
GFCI overload
Oh.... I love pics.... please share!
Old 08-31-2012, 02:11 PM   #7
GFCI overload
YEA, but I was thinking that he wasn't going to try that hard.
I think we have a couple of microwaves like that at work.
Old 08-31-2012, 02:15 PM   #8
GFCI overload
Lets just say pliers and a twisting motion were involved. The pic really isn't clear enough.
Old 08-31-2012, 02:22 PM   #9
E2 Electrician
GFCI overload
I kind of figured that's what transpired. I've seen a few of those installs.
Old 08-31-2012, 02:55 PM   #10
GFCI overload
Thanx to all who answered. The reason I'm asking is because I have a 1800 watt heater that you plug into a wall. That's exactly 15A. I'm preparing a rental unit. You can't always control what happens in a rental unit. If the tenant connects something bigger, say a 2000W heater, then I wanted to know if the GFCI receptacle would act as a circuit breaker. I guess not judging from your answers.
Old 08-31-2012, 03:00 PM   #11
E2 Electrician
GFCI overload
A GFCI contains no over current device.
Replacing kitchen gfci with gfci breakers-something's not right Fpbaum Electrical 14 05-01-2012 09:43 AM
GFCI - White & Black Both HOT? hagler Electrical 11 03-19-2012 09:29 AM
Can you test a non GFCI plug with a GFCI tester? DIYguy2000 Electrical 3 01-16-2012 07:49 AM
GFCI Question Mdbuilder Electrical 6 06-19-2008 04:15 PM
