Old 11-06-2009, 09:09 AM   #1
GFCI outlets question
I have an existing GFCI outlet in our bathroom. It is supplied from a dedicated breaker.
Can I connect another GFCI to the feed line for our 2nd bathroom?
bigcaddy is offline   Reply With Quote
Old 11-06-2009, 09:16 AM   #2
Xtreme DIY'r
You can either connect another GFCI to the LINE side
or you can connect a regular outlet to the LOAD side of the existing GFCI
Old 11-06-2009, 09:18 AM   #3
cool, thanks.
Makes it easier for me.
Old 11-06-2009, 09:31 AM   #4
300zx's Avatar
Post
This site might help http://www.ask-the-electrician.com/G...gh-Method.html also a pic the pic shows no ground wire but if you have a ground HOOK II UP!!!
300zx is offline   Reply With Quote
Old 11-10-2009, 08:17 PM   #5
hooking it up so it functions is different than meeting code. I believe each bathroom needs it's own dedicated circuit, but you should check out the NEC. (disclaimer...just a homeowner guy, not a pro)
steve1234 is offline   Reply With Quote
Old 11-10-2009, 08:31 PM   #6
Xtreme DIY'r
A GFCI protected circuit can supply everything in a bathroom - outlets & lights
OR
It can supply Outlets ONLY in multiple bathrooms
You can connect GFCI's without a ground
It must then be labeled as "NO ground present"
These stickers actually come with the GFCI
Old 11-10-2009, 08:34 PM   #7
300zx's Avatar
Post
I think you are wrong can you show me the code?
Old 11-11-2009, 01:03 PM   #8
Nope. I am most probably wrong. I rewired my house and had my residential pocket NEC book. My previous post was going off memory and I should not have posted such an "opinion".....my bad.
Old 11-11-2009, 01:10 PM   #9
Xtreme DIY'r
I do prefer a dedicated circuit to each bathroom
It just makes sense with the power draw of hair dryers
NEC is the Min requirement, going above in this case is a great idea
Old 11-11-2009, 01:15 PM   #10
300zx's Avatar
Post
I do agree with you if it was my house i would put each gfci in bath on own circuit. Here we put the main GFCI in master bath and load side in guest bath
Old 11-11-2009, 01:21 PM   #11
agreed. I remember the discussion with my inspector and we were joking about our wives with the hair dryers, straightening hot things, and other stuff that all gets plugged in. (To all the wives out there don't take this as a bad thing, it's all good and just the way it is) I had two bathrooms and each one got it's own circuit. That's why I made the comment I did. However I should not have suggested it was "code" without verifying.
Old 11-11-2009, 02:09 PM   #12
Code05's Avatar
Quit apoligizing, there was nothing wrong with your other post, you merely said it may be code and to check the NEC.
You wrote "I believe each bathroom needs it's own dedicated circuit, but you should check out the NEC." Nothing said it was code, you just said it may be.
Code05 is offline   Reply With Quote
Old 11-11-2009, 02:22 PM   #13
300zx's Avatar
I have been guilty of saying the wrong things to but there are great people here that will correct us. We are not perfect
GFCI switch to control outside outlets billgeo Electrical 14 09-09-2008 12:09 AM
GFCI Question dankreboot Electrical 5 08-06-2008 09:33 PM
GFCI in detached garage question WShawn Electrical 2 08-02-2008 04:27 PM
Question about wiring outlets together firemanpato Electrical 5 01-05-2008 04:52 PM
Wiring Design Considerations Question tjandt Electrical 6 09-26-2006 06:44 AM
