Gfci Outlets Not Working - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-27-2007, 11:39 PM   #16
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Hang on a second before we go calling in contractors. It is my understanding you have three gfci's on different circuit breakers that have failed. This is not your normal loose connection problem.
Please answer a question:
Is power present at the gfci's? By this I mean does a tester show the hot wire that is connected to the line terminal of the gfci is at 120 volts or lights a test light when tested to ground?
It would not be feasible for three gfci's on different circuits to all have ground faults.
Also power comes back on when it wants? Please describe what you
mean by that in more detail.
This sounds more like a power problem not a gfci tripping out on fault.
Stubbie
Old 08-27-2007, 11:46 PM   #17
Long-Time DIYer
Mike Swearingen's Avatar
As suggested, you need to check the connections on every single receptacle on each circuit, whether it is a gfci receptacle or not.
Also, don't forget to check for gfci or other receptacles that may have been installed on the opposite wall, but on the same circuit (perhaps in an exterior or garage location).
Mike
Mike Swearingen is offline   Reply With Quote
Old 08-28-2007, 03:28 PM   #18
Ok, I have 2 gfci outlets that have the reset/test buttons on them that are not working. I have one outside that is working. I have other outlets that are also the protected outlets that dont have the reset/test button on them that also are not working. All of the outlets that are not working belong to 3 different circuit breakers. none of the breakers are tripped. The power in just the outlets that belong to those three circuit breakers goes out without any reason. And then usually a few hours later the power in the outlets will just come back on all by itself. But it has not come back on for three days now. I have not used a test light on them yet. I have to get one from someone. The rest of the electricity in the house is fine.
mtkelley is offline   Reply With Quote
Old 08-29-2007, 12:15 AM   #19
UAW SKILLED TRADES
Stubbie's Avatar
I'm trying to find out why you are having issues on three circuits but not others. Why 2 gfci's are tripping or if they are not resetting because they are not powered. The test I asked about would be very helpful. I would like to know if all has been well with these until now or if you have had trouble with them for some time? I would also like to know the wiring description in the boxes at the gfci's. Like the colors of wires and where they are connected on the gfci. Anybody been fooling with the wiring lately?
When you say 2 gfci's are tripping are they both on the same circuit or different circuits?
Do you know what a multiwire circuit is that uses a shared neutral wire. Would you know how to recognize one?
Sorry for all the questions but I'm trying to get a better understanding of what is going on there.
stubbie
Old 08-29-2007, 12:12 PM   #20
Weekend Builder
Crackers's Avatar
Do you have 2 GFI in the same line? For example, a GFI in the bathroom, then the power line keeps going to another GFI in the other bathroom?
Or another example: GFI in your pool shed, and the same line is taken from another GFI inside the home??
Crackers is offline   Reply With Quote
Old 08-29-2007, 03:43 PM   #21
Rewards Points: 150
This is going on much too long ... we're getting dubious information.
MT,
If you have children in this trailer ... I highly recommend you get a licensed contractor out there FAST before something happens.
Stop this screwin' around, get it fixed prorperly for the sake of the children.
I don't wanna' see your children on Channel 7 News.
Take Care...
JGarth is offline   Reply With Quote
Old 08-29-2007, 03:47 PM   #22
UAW SKILLED TRADES
Stubbie's Avatar
Yes, at this point I am afraid I have to agree with Garth...you need to get a professional out asap. I originally thought I had a clue to what was going on but the information is no longer supporting that thought. Plus I think your skills are not going to be able to correct a problem like you are having..... that isn't met as an insult just concern for your family safety.
stubbie
Old 08-29-2007, 03:54 PM   #23
Rewards Points: 150
Stubbie,
I agree ... it's nothin against MT... some folks are better suited for other endeavors .... this is starting to worry me ...
I'm retired,..... if he lived closer ... I run out there and take care of it ... he's 1.5 hrs away ... one way... and it's way accross Detroit ... no good way to get there ....
GO YANKEES .....
Nite .....
Old 09-07-2007, 03:19 PM   #24
Problem solved. Thanks to all that helped. It ended up being the main breaker outside at the pole. It was corroded. I didn't even know it was there. Thanks again
Kitchen outlet breaker simma Electrical 3 02-28-2007 05:50 PM
Problem W/ Power after Switching Outlets... G19-Fanatic Electrical 17 08-28-2006 01:55 PM
Replacing light killed downstream outlets, totally stuck amissner Electrical 5 07-13-2006 06:02 AM
two GFCI outlets at bath vanity Hickory Electrical 6 12-18-2005 09:31 AM
wiring a gfci outlet in circuit bobo Electrical 12 08-31-2005 08:38 PM
