Gfci Outlets Not Working - Electrical - DIY Chatroom Home Improvement Forum
Old 08-26-2007, 05:46 PM   #1
Question
gfci outlets not working
I live in a manufactured home and my GFCI outlets aren't working. I've tried reseting all of them but they wont reset. There are 3 different circuit breakers contected to all of the outlets that aren't working and none of them are tripped. The power comes back on eventually when it wants to and will eventually go back out. I have one GFCI outlet that is working and that is the outside outlet. Please, any help will be appreciated.
mtkelley is offline   Reply With Quote
Old 08-26-2007, 05:55 PM   #2
Long-Time DIYer
Mike Swearingen's Avatar
I am NOT an electrician, just an old DIYer. IMHO, you apparently have one with a faulty connection or one that has failed in that circuit.
Turn OFF the breakers to the circuits, and check to see if any of the screw connections are burned, corroded or loose.
If all looks o.k., start exchanging the gfci receptacles for new ones. There should not be more than one gfci on a circuit, and it should be the first one, so that all past it in that same circuit would also be gfci protected.
That's just my 2 cents.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 08-26-2007, 06:13 PM   #3
I've taken the panel off of the circuit box and everything is tight and clean.
Old 08-26-2007, 06:25 PM   #4
Master Electrician
JohnJ0906's Avatar
Have you checked each GFCI receptacle? Or are these GFCI Breakers?
Check ALL connections on the circuit. (Deenergized, of course)
How old are the GFCIs? More than 10-15 years, you may need to replace them.
John from Baltimore
One Day at a Time
"Experience is what you get when you were expecting something else"
"The bitterness of low quality lingers long after the sweetness of low cost is forgotten"
JohnJ0906 is offline   Reply With Quote
Old 08-26-2007, 06:30 PM   #5
the home is 5 years old. they are receptacles and they will not reset
Old 08-26-2007, 10:46 PM   #6
Rewards Points: 150
MT,
Are you located in SE Michigan ... if so, which mobile home park...
JGarth
JGarth is offline   Reply With Quote
Old 08-27-2007, 03:16 PM   #7
I live in Chesterfield
Old 08-27-2007, 03:38 PM   #8
Rewards Points: 88
Are you pushing the trip button first?
J. V. is online now   Reply With Quote
Old 08-27-2007, 03:45 PM   #9
Rewards Points: 150
Sorry....too far...
I'm way south of you in Grosse Ile....
Old 08-27-2007, 04:53 PM   #10
i've tried to test/reset but it wont let me, none of them. none of the circuits are tripped.
Old 08-27-2007, 05:23 PM   #11
Rewards Points: 150
Have you opened up all the receptacle boxes and looked for a "loose" connection. ... on the recptacle itself, or possibly a "wire-nutted" connection.
Do you have anything like a hair dryer, electric tootbrush, etc....plugged into any GFCI receptacle or on downstream of it.
Old 08-27-2007, 07:31 PM   #12
I just checked the outlets that have the test/reset on them and they look fine. No loose wires. I've unpluged everything.
Old 08-27-2007, 07:40 PM   #13
Rewards Points: 150
Also.......check the receptacles downstrean of the GFCI...is anything plugged into them..
Next step .... call a contractor...
Old 08-27-2007, 07:51 PM   #14
nothing plugged into any of the protected outlets
Old 08-27-2007, 08:09 PM   #15
Custom Cabinet Maker
call electrician Now is a good time before something horrible happens
skymaster is offline   Reply With Quote
Kitchen outlet breaker simma Electrical 3 02-28-2007 06:50 PM
Problem W/ Power after Switching Outlets... G19-Fanatic Electrical 17 08-28-2006 02:55 PM
Replacing light killed downstream outlets, totally stuck amissner Electrical 5 07-13-2006 07:02 AM
two GFCI outlets at bath vanity Hickory Electrical 6 12-18-2005 10:31 AM
wiring a gfci outlet in circuit bobo Electrical 12 08-31-2005 09:38 PM
