GFCI Outlets Needed - Electrical - DIY Chatroom Home Improvement Forum
Old 05-08-2012, 03:10 PM   #1
GFCI Outlets Needed
I have an older house that does not have any GFCI outlets. Is there any particular brand or model that is better, or should I just goes buy the Lowes or Home Depot stocked item?
And is this as simple as replacing the existing outlet, or is there something else that also needs to be done?
jdjd is offline   Reply With Quote
Old 05-08-2012, 03:27 PM   #2
...here's a vid that may help. http://www.wonderhowto.com/how-to-in...itchen-419236/
fullpint is offline   Reply With Quote
Old 05-08-2012, 03:57 PM   #3
Licensed electrician
Rewards Points: 1,884
Any of the major brands should be fine.
You will need to determine the incoming power from the outgoing power if you wish downstream protection to other receptacles. The incoming power goes to the LINE terminals.
Replacing kitchen gfci with gfci breakers-something's not right Fpbaum Electrical 14 05-01-2012 08:43 AM
Low-voltage track light triggers GFCI outlets mpf01 Electrical 4 11-08-2011 09:15 PM
Landscape wiring question: GFCI and Breaker Amp MikeInDetroit Electrical 0 11-02-2011 09:43 AM
GFCI Outlets in Series allbymyself Electrical 6 01-24-2011 11:52 PM
Problem with GFCI Outlets in Kitchen mkrawitz Electrical 13 04-14-2010 08:35 PM
