Old 01-08-2007, 11:40 PM   #1
GFCI outlet vs. breaker - GF trip speed
I was chatting with an electrical safety consultant at work the other day. He is claiming that a GFCI outlet will trip due to a ground fault faster (and thus offer enhanced personal protection) than same circuit protected with a GFCI breaker. I have a hard time believing this. Transmission line effects should be negligible in household wiring and I have a hard time believing the electronics in breaker and the outlets are substantively different. A quick google search revealed nothing. Has anyone ever heard of this before? If it’s true can anyone explain why?
LanterDan is offline   Reply With Quote
Old 01-09-2007, 12:03 AM   #2
LanterDan,
I have never heard of this difference. The only advantage that I attribute to GFCI receptacles is resetting at the tripped location.
While my experience is not statistically significant, I have seen many GFCI receptacles fail and require replacement. I have never seen a GFCI circuit breaker fail - they seem to be better quality.
...Christopher
Christopher is offline   Reply With Quote
Old 01-09-2007, 07:05 AM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
I will say I have definitely seen both fail. I think devices fail more often because of 1) The environment they are usually installed in {ie: outside and garages, etc}, and 2) There are FAR more GFI devices than breakers.
So statistically there will be far more device failures than breakers, making breakers look more reliable.
New GFCI Breaker Tripping w/ 3-way Flourescents BigJimmy Electrical 8 12-29-2008 03:29 PM
Breaker for Spot light and outlet receptical hgiljr Electrical 4 08-16-2007 02:10 PM
Kitchen outlet breaker simma Electrical 3 02-28-2007 06:50 PM
GFCI breaker problems bwoo Electrical 5 12-09-2006 03:53 PM
delayed breaker trip flyrod Electrical 6 12-30-2005 10:06 PM
