Gfci Outlet Making Loud Noise - Electrical - DIY Chatroom Home Improvement Forum
Old 04-14-2011, 08:29 PM   #1
Gfci outlet making loud noise
We had a tree come down and knock out power for a few hours. After power was restored we noticed the 2 gfi recepticals next to our sink stopped working. I tried to reset but nothing would work. I replaced both recepticals with new gfci recepticals, mirrored the original wiring but when I turn the breaker back on it makes a loud noise from one of the new gfci recepticals. Any ideas what is going on?
Macboo is offline   Reply With Quote
Old 04-14-2011, 09:04 PM   #2
Does it make the noise after you press the test button? Are both on the same circuit?
clydesdale is offline   Reply With Quote
Old 04-16-2011, 07:30 AM   #3
It does. The noise only comes from one receptical and it's pretty loud and nothing changes if I hit reset or test. They are on the same circuit/breaker.
Old 04-16-2011, 07:39 AM   #4
Electrical Contractor
kbsparky's Avatar
Bad GFCI unit. Replace it with another one.
-KB
Old 04-16-2011, 11:48 AM   #5
Thanks KB! Replaced the one with another new gfci receptical and is working like a charm. Back in business! Thanks again.
Another puzzling question about GFCI outlet Giles Electrical 3 02-20-2010 01:00 PM
Replacing outlet to new GFCI - Wall switch Protonix Electrical 13 04-09-2009 08:36 AM
GFCI from basement laundry to outdoor outlet TPS Electrical 11 01-15-2009 12:17 AM
GE side-by-side making a whining noise jkrodger Appliances 2 09-11-2007 02:45 PM
Toilet making Noise DSHMSH Plumbing 1 12-22-2005 04:33 PM
