Old 02-10-2007, 02:16 PM   #1
GFCI Outlet installation in bathroom...
When I install the GFCI outlet in my bathroom, can I also connect the lights and fan to this same circuit? If yes, should they split off before the the outlet or does it matter?
budde97 is offline   Reply With Quote
Old 02-10-2007, 05:04 PM   #2
jproffer's Avatar
Yes, but only if that is the ONLY room on the circuit. That's the code....now here's my opinion: It's not a good idea...the GFI trips and now you're also in the dark.
Doesn't matter.
jproffer is offline   Reply With Quote
Old 02-10-2007, 09:50 PM   #3
remodeling pro
Doesn't matter.
Does in fact matter, because if the lighting is tapped off of the feed upstream of the GFCI, it will not lose power when the GFCI trips. I,m talking a GFCI receptacle in the bath, if it is a GFCI breaker, you will indeed lose power to the lights.
troubleseeker is offline   Reply With Quote
Old 02-11-2007, 12:45 AM   #4
Thank you for the replies. I have read that if the overhear fan/light is near the shower (wet location) that it needs to be on a GFCI as well. I have not heard of that before, and I am not sure if I have seen this in any other house. This would make a difference on how it is wired with respect to the outlet. Does anyone know if this is correct?
Old 02-11-2007, 01:22 AM   #5
Never mind. I spent some more time reading other posts and have my question answered.
Wiring in New Addition? sandyman720 Electrical 6 11-27-2011 04:34 PM
outlet in bathroom cabinet OK? matty Electrical 5 08-02-2007 10:56 PM
Bathroom outlet - distance from tub?? plbsplbs Electrical 11 07-09-2007 09:22 PM
Extending a GFCI in the bathroom diamondking Electrical 10 05-01-2007 06:48 PM
wiring a gfci outlet in circuit bobo Electrical 12 08-31-2005 09:38 PM
