-   -   GFCI Outlet installation in bathroom... (http://www.diychatroom.com/f18/gfci-outlet-installation-bathroom-6415/)
budde97 02-10-2007 01:16 PM
When I install the GFCI outlet in my bathroom, can I also connect the lights and fan to this same circuit? If yes, should they split off before the the outlet or does it matter?
jproffer 02-10-2007 04:04 PM
Yes, but only if that is the ONLY room on the circuit. That's the code....now here's my opinion: It's not a good idea...the GFI trips and now you're also in the dark.
Doesn't matter.
troubleseeker 02-10-2007 08:50 PM
Doesn't matter.
Does in fact matter, because if the lighting is tapped off of the feed upstream of the GFCI, it will not lose power when the GFCI trips. I,m talking a GFCI receptacle in the bath, if it is a GFCI breaker, you will indeed lose power to the lights.
budde97 02-10-2007 11:45 PM
Thank you for the replies. I have read that if the overhear fan/light is near the shower (wet location) that it needs to be on a GFCI as well. I have not heard of that before, and I am not sure if I have seen this in any other house. This would make a difference on how it is wired with respect to the outlet. Does anyone know if this is correct?
budde97 02-11-2007 12:22 AM
Never mind. I spent some more time reading other posts and have my question answered.
