GFCI Outlet Feeding Sub Panel - Electrical - DIY Chatroom Home Improvement Forum
Old 07-13-2010, 11:21 AM   #1
Question
GFCI outlet feeding sub panel
I volunteered to help my co-worker wire up his new detached garage, but the situation his builder left me in has me slightly puzzled
He has:
  • already buried cable (14/3)
  • inside the house each wire in the cable is connected to a 15A breaker
  • it runs to a GFCI outlet on the deck where 1 wire serves this outlet
  • it then runs underground to an outlet on a post by his garage where the same wire serves that outlet and the other one is just inside doing nothing
So it is pretty sucky that all he has to work with is 15A and there's nothing I can do about that. Stupid builder doing minimum to code.
My question is: can I run a sub-panel off this circuit even though it is fed by a GFCI outlet? Not even sure if a sub-panel is worth it here because I'm still limited to 15A per side. But i guess it's better for him to be able to cut power to something if needed. Or should I just come into the garage and split it into max 12 devices per circuit?
Thanks.
tdola is offline   Reply With Quote
Old 07-13-2010, 02:15 PM   #2
mechanical engineer
I don't see any point in a sub panel. Just use the 14-3 and make two 15A circuits with a shared neutral. Be sure the breakers are on different phases and either link the breaker handles or use a 2-pole that insures that both circuits must be shut off at the same time.
The GFCI should not be an issue. Garage outlets should be GFCI protected.
dave53 is offline   Reply With Quote
Wiring a GFCI Outdoor Outlet from an Inside Outlet - Parallel or Series? Pacal Electrical 28 11-13-2010 03:36 PM
GFCI in the bathroom trouble canyonbc Electrical 7 01-26-2010 02:36 AM
feeding 4-wire grd sub off old panel kninja1211 Electrical 4 11-18-2009 07:59 PM
Replacing kitch outlets to GFCI jhubert Electrical 7 11-16-2009 07:23 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 09:33 AM
