GFCI Outlet & Electric Smoker - Electrical - DIY Chatroom Home Improvement Forum
Old 09-10-2011, 08:05 PM   #1
GFCI outlet & electric smoker
I can not use my electric smoker on a GFCI. IT always trips. Is that due to the concept of the wet wood on the element w/in the smoker? The smoker does not trip the breaker when on a drop cord from a regular outlet.
aleciadooley is offline   Reply With Quote
Old 09-10-2011, 08:14 PM   #2
Code05's Avatar
Rewards Points: 1,104
It means your smoker is going to electrocute you someday or the GFCI is bad.
Appliances function fine on modern working GFCIs, unless the appliance has a current leakage problem.
Plug it into another GFCI and see if the GFCI trips.
Code05 is offline   Reply With Quote
Old 09-11-2011, 07:17 AM   #3
Semi-Pro Electro-Geek
Rewards Points: 2,902
Sounds like your smoker has a ground fault. Probably should get that taken care of. It's dangerous.
mpoulton is offline   Reply With Quote
Old 09-11-2011, 07:52 AM   #4
Electrical Contractor
kbsparky's Avatar
Your smoker must be smoked ....
-KB
Old 09-11-2011, 01:07 PM   #5
jbfan's Avatar
Rewards Points: 252
Check for a loose connection at the receptacle.
I fiund one for a customer one time, wire not tight on the receptacle.
He only used the receptacle for his electric grill.
Tags
electric smoker , gfci outlet
electric outlet rafa7 Electrical 0 04-22-2011 08:07 AM
Covering an electric outlet with cabinets Georgejc Electrical 15 04-20-2011 11:52 PM
How to include a GFCI outlet with multiple loads Gwennr Electrical 5 10-13-2010 11:31 AM
Flourescent light using GFCI outlet Willing2learn Electrical 5 09-12-2010 08:27 PM
Treadmill on GFCI outlet? fw2007 Electrical 13 10-21-2008 02:49 PM
