GFCI Outlet - Buzz Noise - Electrical - DIY Chatroom Home Improvement Forum
Old 10-18-2011, 12:43 PM   #1
Rewards Points: 33
GFCI outlet - buzz noise
I heard some buzz noise (not too loud) from two of the new Leviton's GFCI outlet I purchased recently. I am wondering if they are bad or this is just normal.
Thanks.
cfreak is offline   Reply With Quote
Old 10-18-2011, 01:03 PM   #2
I just installed several Leviton Smart Lock Pro GFCI's. I just went and put my ear up to them. Did not hear a thing.
Do you have a green light and is it on? Outlets working?
Why did you install these? Replacement and previous problem? New?
Is there anything connected to the load side?
Difference with something plugged in or nothing plugged in?
Billy_Bob is offline   Reply With Quote
Old 10-18-2011, 01:26 PM   #3
" Euro " electrician
frenchelectrican's Avatar
A properly installed GFCI will not make any noise at all.
Did you hit the test button and reset it ? if so and the noise still there you will need to check it closer and what room this GFCI is located and what receptale it serve ??
Once you answer the question we can dail down excatally what is going on.
Merci,
Marc
Porch outlet, and livingroom on bathroom GFCI circuit? Is that uncommon? 211 Electrical 5 01-06-2011 03:13 PM
GFCI outlet failed in a rain storm, now has no power! Kaybee33 Electrical 5 12-28-2010 06:38 PM
Flourescent light using GFCI outlet Willing2learn Electrical 5 09-12-2010 08:27 PM
Sump Pump and GFCI Outlet sweetwaters Electrical 10 03-20-2010 07:01 PM
trouble with my gfci outlet derek10790 Electrical 8 03-17-2010 09:54 AM
