Hello all! This is my first post here so here it goes.
I am doing some renovation in the bathroom - new drywall, tiling, fixtures, etc.
The bathroom is very old and has 1 lightswitch that is on the same circuit as the bedroom (says 15 on the panel, assuming 15 amps).
Also has 1 outlet that was not GFCI but I am thinking I should install a GFCI for code/protection, since it is right above the sink. I included a few pictures of the outlet in question here:
http://imgur.com/a/JS7sX
I have changed all of the regular wall outlets in the home that had either 3 or 5 wires, but the ground always seemed to be the copper wire, but in this outlet there is the extra white wire attached to the bottom of the outlet, is that the ground, or something else?
The number on the panel says 20, once again, i'm assuming that means 20 amps. It seems to be on the same circuit as the bathroom adjacent to it and one of the living room outlets downstairs.
I have been doing a lot of research on the forums and it seems like a GFCI is necessary, and a 15 amp GFCI would be okay with a 20 amp circuit. But I just want some of your opinions on what I should do (short of rewiring anything).
Thanks in advance for everything! :thumbup:
