GFCI Outlet Add On Question. - Electrical - DIY Chatroom Home Improvement Forum
Old 05-09-2014, 08:43 PM   #1
Rewards Points: 1,470
GFCI outlet add on question.
I need to install an outlet on a large covered porch (12' deep x 24' wide) that was added on, and the only reasonable way to wire it is to tie into a guest bedroom outlet where the outlets would be back to back (walls are all built with 2x6 studs).
Any reason I can't wire out of the bedroom outlet, and install a GFCI outlet on the porch?
The only reason for the outlet is to please the wifey, as she wants to be able to put a Christmas tree on the porch....
ktkelly is offline   Reply With Quote
Old 05-09-2014, 09:52 PM   #2
dmxtothemax's Avatar
Rewards Points: 5,496
Is the existing circuit able to carry the extra load ?
Is it exposed to the weather or elements ?
If so you have to use the correct enclosure or type.
Otherwise should be ok.
Have you checked code requirements for your area ?
dmxtothemax is offline   Reply With Quote
Old 05-10-2014, 01:15 PM   #3
Since there's only a total of 6 outlets on the circuit, with only three that are being used for two table lamps and a TV, I see no issues with the load.
Only if there's a hurricane, and then the power would be off anyway.
[quote]If so you have to use the correct enclosure or type./QUOTE]
I planned on using a outdoor cover.
If I follow code, I'll be one of the few on the island that do.
Old 05-11-2014, 08:06 AM   #4
Electrical Contractor
Philly Master's Avatar
Rewards Points: 516
i see no problems with it ... based on a weather proof GFI and proper cover ...the porch should have had an outlet by code anyway
Philadelphia Master Electrician-Generac Dealer
Philly Master is offline   Reply With Quote
Old 05-11-2014, 08:25 AM   #5
Surprisingly the outlet wasn't required by the local, next to nonexistent, planning department that issues permits, does inspections, etc, etc.
I looked at a lot of other places before buying this one, and the amount of serious code violations I found on most, was absolutely astounding.
On this particular one, all of the ceiling fans were mounted to the trusses with no back boxes. The wiring was simply pushed through a hole in the ceiling and wire nuts used to connect it to some 14-2 romex tied to the feed for the attic vent fan. No junction boxes anywhere and the grounds weren't used at all.
Oh the things I found!
Old 05-11-2014, 08:30 AM   #6
Rewards Points: 516
it is required by NEC code .... if i remember correctly and "deck" 20 sq. ft or more, ...
Wiring question: GFCI and light switch diy888 Electrical 11 10-10-2013 08:30 PM
gfci outlet outside? Toller Electrical 1 09-16-2013 05:06 PM
Bizarre GFCI outlet problem gbreton Electrical 13 01-02-2013 08:15 AM
Circuits in Garage and GFCI tedallen Electrical 19 05-24-2012 07:03 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 09:33 AM
