Gfci Outlet - Electrical - DIY Chatroom Home Improvement Forum
Old 11-11-2010, 11:35 PM   #1
gfci outlet
I can not find a gfci breaker for my panel.So instead i am thinking to put a gfci receptacle between the panel and the circuit. I mean one end to the panel and the other end of the cfci(load) the circuit that goes to the 2nd floor.You think it is OK ? thanks
gefeiora is offline   Reply With Quote
Old 11-12-2010, 12:20 AM   #2
Electrical Contractor
kbsparky's Avatar
What brand is your panel?
-KB
Old 11-12-2010, 05:38 AM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,956
That's how most people do it.
Is this for something special, like a bath tub heater/motor?
Old 11-12-2010, 06:20 AM   #4
the breaker is CEB . Is discontinue, besides would cost over 100 dollars.The reason is : the second floor there is no grounding for lights and outlets in bathroom and the bedrooms, so i think a good idea to do this.So you think it is OK? thanks
Old 11-12-2010, 10:48 AM   #5
Rewards Points: 150
... so you get one or more of these:
http://www.google.com/products/catal...d=0CF4Q8wIwCA#
Remember to label all of the receptacles "GFCI-protected" and "No Equipment Ground".
emolatur is offline   Reply With Quote
Old 11-12-2010, 11:13 AM   #6
WHY bother with that?? Just change the first existing receptacle to a GFI and be done with it.
Old 11-12-2010, 06:52 PM   #7
thanks. It's hard to find the first outlet, that's why i want to make the first one right from the panel. Even put it inside the cabinet where is the panel.So, you think it's OK ?
Old 11-12-2010, 06:57 PM   #8
A GFCI will not give you any grounding
If you are running electronics/computer equipment you are better off running a ground
Old 11-12-2010, 09:29 PM   #9
in the bathroom it's easy. Just a green wire from cold pipe to outlet(permitted in Canada).But for the computer need to run the wire on baseboard and around doors etc.But the other way still protects the person, I guess.!!? I'll try to find the best way to get ground to the computer. Thanks
Old 11-13-2010, 05:49 AM   #10
Are you in Canada? Your profile is conspicuously empty.
Also, even if this is allowed, it is NOT a good idea. Why do you think the US removed this allowance many, many years ago??
A cold water pipe IS NOT usually a valid source of an electrical "ground", or "bond" for a more accurate term.
Old 11-13-2010, 10:17 AM   #11
Somebody in this forum said it was allowed in canada. Must be, because the panel is ground to the main water tap and the inspector the first thing he was looking for was the ground, so the bathroom pipes are already grounded.Is it unsafe if i connect the ground from the pipe to the outlet ? How they do in States? Put a cooper rod in the ground ?Thanks
Old 11-13-2010, 12:36 PM   #12
A rod stuck in the ground has absolutely NOTHING to do with the round hole in a receptacle. They are two totally different types of "ground".
In the US it is only acceptable to connect a circuit ground to a water pipe that is beyond 5' of where it enters (not just any old water pipe), and then ONLY if that pipe is correctly used as a grounding electrode. This means that the grounding electrode conductor is what is being used as the equipment ground path back to the panel, NOT the pipe in the earth.
With the widespread use of PVC, CPVC, Pex, etc, there is a very good chance the continuity path of the piping back to the bond point is compromised, or will be compromised.
Wiring a GFCI Outdoor Outlet from an Inside Outlet - Parallel or Series? Pacal Electrical 28 11-13-2010 03:36 PM
Help with an exterior GFCI Outlet!!??!! Brad2723 Electrical 1 03-31-2010 09:46 PM
trouble with my gfci outlet derek10790 Electrical 8 03-17-2010 08:54 AM
GFCI Breaker & GFCI Outlet together??? abinpa General DIY Discussions 6 04-12-2009 08:59 PM
Treadmill on GFCI outlet? fw2007 Electrical 13 10-21-2008 01:49 PM
