GFCI Outlet - Electrical - DIY Chatroom Home Improvement Forum
Old 09-07-2010, 09:19 PM   #1
GFCI outlet
I want to put a GFCI outlet in series with other outlets so they will be protected also, does the GFCI outlet have to be the first in the series for them to be protected or can it be anywhere in the series?
rlaurent79 is offline   Reply With Quote
Old 09-07-2010, 09:23 PM   #2
Licensed electrician
Rewards Points: 1,226
In order for the standard receptacles to be protected by the GFI they must be wired from the LOAD terminals and be downstream of the GFI device.
Wiring a GFCI Outdoor Outlet from an Inside Outlet - Parallel or Series? Pacal Electrical 28 11-13-2010 04:36 PM
Help with an exterior GFCI Outlet!!??!! Brad2723 Electrical 1 03-31-2010 10:46 PM
GFCI Breaker & GFCI Outlet together??? abinpa General DIY Discussions 6 04-12-2009 09:59 PM
Treadmill on GFCI outlet? fw2007 Electrical 13 10-21-2008 02:49 PM
GFCI Question Mdbuilder Electrical 6 06-19-2008 04:15 PM
