GFCI Outlet - Electrical - DIY Chatroom Home Improvement Forum
Old 12-03-2012, 04:30 PM   #1
GFCI Outlet
My microwave is on the counter next to the sink. It is plugged into a GFCI outlet. Several days ago while cleaning the water on the counter, my wife got a shock. The GFCI did not shut down. I immediately replaced it. Today my wife again got a shock. The outlet did shut down. I called the company. They said that the unit should shut down before getting a shock. I would appreciate any insight into this problem.
thanks
daniell59 is offline   Reply With Quote
Old 12-03-2012, 04:39 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 224
Did she get a shock from the microwave?
This should be moved to the electrical section.
Old 12-03-2012, 04:47 PM   #3
The wet counter near the microwave. Only happens when the microwave is plugged in and the counter is wet.
Old 12-03-2012, 05:45 PM   #4
Rewards Points: 1,294
The shock she is getting may not exceed the trip threshhold for the GFCI. Sounds like the microwave has a small current leak. When she gets the shock, where is her other hand? Is she touching something else. To get a shock, current needs to flow somewhere to complete the circuit.
danpik is offline   Reply With Quote
Old 12-03-2012, 07:30 PM   #5
Rewards Points: 3,398
Is this a 2 wire system,sounds like she's the better path to ground with a wet counter.
Canarywood1 is offline   Reply With Quote
Old 12-04-2012, 07:28 AM   #6
Rewards Points: 5,974
Use the test button on your GFI and make sure it's wired and working properly. Is there a chance this is a static electric shock.
The Following User Says Thank You to ToolSeeker For This Useful Post:
joecaption (12-04-2012)
Old 12-04-2012, 09:58 AM   #7
PoleCat's Avatar
Rewards Points: 1,646
Have a good look at the chord for cracks or knicks in the insulation.
PoleCat is offline   Reply With Quote
Bathroom GFCI Outlet trouble RyG1357 Electrical 3 08-20-2011 04:40 PM
Changing Two Gang Outlet to Three Gang Outlet vbullinger Electrical 9 01-10-2011 06:13 PM
Porch outlet, and livingroom on bathroom GFCI circuit? Is that uncommon? 211 Electrical 5 01-06-2011 03:13 PM
GFCI outlet failed in a rain storm, now has no power! Kaybee33 Electrical 5 12-28-2010 06:38 PM
Replacing outlet to new GFCI - Wall switch Protonix Electrical 13 04-09-2009 09:36 AM
