-   -   GFCI Outlet (http://www.diychatroom.com/f18/gfci-outlet-165499/)
daniell59 12-03-2012 03:30 PM
GFCI Outlet
My microwave is on the counter next to the sink. It is plugged into a GFCI outlet. Several days ago while cleaning the water on the counter, my wife got a shock. The GFCI did not shut down. I immediately replaced it. Today my wife again got a shock. The outlet did shut down. I called the company. They said that the unit should shut down before getting a shock. I would appreciate any insight into this problem.
thanks
jbfan 12-03-2012 03:39 PM
Did she get a shock from the microwave?
This should be moved to the electrical section.
daniell59 12-03-2012 03:47 PM
The wet counter near the microwave. Only happens when the microwave is plugged in and the counter is wet.
danpik 12-03-2012 04:45 PM
The shock she is getting may not exceed the trip threshhold for the GFCI. Sounds like the microwave has a small current leak. When she gets the shock, where is her other hand? Is she touching something else. To get a shock, current needs to flow somewhere to complete the circuit.
Canarywood1 12-03-2012 06:30 PM
Is this a 2 wire system,sounds like she's the better path to ground with a wet counter.
ToolSeeker 12-04-2012 06:28 AM
Use the test button on your GFI and make sure it's wired and working properly. Is there a chance this is a static electric shock.
PoleCat 12-04-2012 08:58 AM
Have a good look at the chord for cracks or knicks in the insulation.
