Gfci Outlet - Electrical - DIY Chatroom Home Improvement Forum
Old 06-30-2011, 06:41 PM   #1
gfci outlet
I purchased a home that was completely redone, electrical, plumbing, etc. My problem is that the laundry has a gfci outlet that keeps tripping. It's connected to a 20 amp breaker and it's the only line connected to it. the washer and dryer are connected to this outlet and it usually trips when there is a cycle change such as after the washer has filled with water and it switches over to start to wash even if the dryer is not running. What could be wrong?
cowboyfan is offline   Reply With Quote
Old 06-30-2011, 08:48 PM   #2
Jack of all trades
danrb007's Avatar
Send a message via Yahoo to danrb007
GFCI's will trip on occasion when an appliance with a motor is plugged into it. Check code and see if you can swap it out with a regular plug. Also is it a 20amp GFCI or a 15amp GFCI?
danrb007 is offline   Reply With Quote
Old 06-30-2011, 09:31 PM   #3
Licensed electrician
Rewards Points: 1,268
The motor must be leaking too much current. It should be repaired or replaced.
Changing Two Gang Outlet to Three Gang Outlet vbullinger Electrical 9 01-10-2011 06:13 PM
GFCI outlet failed in a rain storm, now has no power! Kaybee33 Electrical 5 12-28-2010 06:38 PM
Wiring a GFCI Outdoor Outlet from an Inside Outlet - Parallel or Series? Pacal Electrical 28 11-13-2010 04:36 PM
Help with an exterior GFCI Outlet!!??!! Brad2723 Electrical 1 03-31-2010 10:46 PM
GFCI Breaker & GFCI Outlet together??? abinpa General DIY Discussions 6 04-12-2009 09:59 PM
