GFCI Outdoors - Electrical - DIY Chatroom Home Improvement Forum
Old 09-10-2012, 07:50 PM   #1
GFCI outdoors
How many GFCI should one have on a Circuity for the outdoors. I always heard that only one was needed and that would be the one closest to the breaker box. Is this true? Or is more then one needed ? Thanks George
geo422 is offline   Reply With Quote
Old 09-10-2012, 07:53 PM   #2
Resi EC
Rewards Points: 252
It used to be 'no more than 6', but any more they all say as may as you want.
Atleast thats what I was told. If you're planning on larger loads might want more circuits, all depends on what you doing.
Gac66610 is offline   Reply With Quote
Old 09-10-2012, 08:37 PM   #3
Master Electrician
Rewards Points: 3,808
An exterior recep is required on the front and on the rear of the house. A recep is also required within 25' of the HVAC equipment.
brric is offline   Reply With Quote
Old 09-10-2012, 08:41 PM   #4
Let me ask it this what is the purporse of having a gfci as soon as the wire exits the house, then at the next outlet put another gfci and so forth. Just because it all outside isn't one gfci enough at least certain number of outlets?Today I replace a floodlight for my friend it was protected by a gfci then an photo cell then the light. I called my friend and ask if the ight was on. he told me that the gfci on the side of house was not working. And he didn't know how many gfci was on the circuity that the light was on. Why so many downstream from each other?
Old 09-10-2012, 08:44 PM   #5
Electrical Contractor
jbfan's Avatar
Rewards Points: 382
Yes it is ok.
jbfan is online now   Reply With Quote
Replacing kitchen gfci with gfci breakers-something's not right Fpbaum Electrical 14 05-01-2012 08:43 AM
Adding GFCI receptacle outdoors Dale Gribble Electrical 2 03-21-2012 01:18 PM
GFCI wiring for a jetted bathtub couchpotato Electrical 13 03-20-2012 11:26 AM
GFCI - White & Black Both HOT? hagler Electrical 11 03-19-2012 08:29 AM
GFCI Question Mdbuilder Electrical 6 06-19-2008 03:15 PM
