GFCI Outdoor Covered Porch - Electrical - DIY Chatroom Home Improvement Forum
Old 08-01-2010, 12:20 AM   #1
GFCI outdoor covered porch
greetings everyone,
i installed a flush duplex receptacle for a wall mounted plasma in my covered back porch. a neighbor told me i should have installed a gfci receptacle since it was outside. the back porch roof extends 15' from the house so i figured should it rain, there is no way water will get to that wall...unless there is a hurricane or some freakish storm. being behind the tv, i seriously doubt i will be plugging anything else in that receptacle. am i violating the code?
thanks!
cept is offline   Reply With Quote
Old 08-01-2010, 07:20 AM   #2
Licensed electrician
Rewards Points: 1,494
Exterior receptacles are required to be GFI protected.
Old 08-01-2010, 11:08 AM   #3
thanks for your reponse.
i know the answer may not always be what people wanna hear.
i tried doing a search before seeking help here and did run across different answers for a similar situation. they kept refering to 210.8 i was further confused about what the 2008 code said about dedicated and unreachable receptacles exemption. if you could help me understand that i would greatly appreciate it.
thanks!
Old 08-01-2010, 11:16 AM   #4
As I undertsand
Exterior receptacles, unless in an enclosed stucture are always considered a wet/damp location & need GFCI
In my detached pool cabana every outlet & light are GFCI protected
Wind can & will blow rain everywhere in a good storm
So even tho its 15' in under a porch roof it can get wet
In addition a future owner may plug an extension cord in & use the outlet for power in the yard
Its not always about your intended use, but rather about possible uses
Old 08-01-2010, 11:18 AM   #5
I=E/R
a7ecorsair's Avatar
Prior versions of the NEC has some exemptions for GFCI outlets. The 2008 NEC eliminated most if not all of these exemptions.
You have a plasma TV hanging on an outside wall that is not fully protected from the weather?
a7ecorsair is offline   Reply With Quote
Old 08-01-2010, 11:54 AM   #6
thanks. i will do as suggested.
now for other dilema, should i use a bubble or just a plain weatherproof cover?
how many predicated i would ask?
Old 08-01-2010, 12:07 PM   #7
Electrician
Proby's Avatar
I don't know if either one would fit behind the TV.
Anything fun is either illegal, immoral, or fattening.
Proby is offline   Reply With Quote
Old 08-01-2010, 04:37 PM   #8
The weatherproof in use cover would be needed. If the box isn't already installed perhaps they can use one of these.
http://www.arlcatalog.com/Weatherpro...nstruction.htm
If existing,
Old 08-01-2010, 04:44 PM   #9
I figured the location would be considered a damp location
So in use bubble cover not required
Old 08-06-2010, 07:12 PM   #10
Checked...406.8...damp location....bubble not required
...under a roof...not subject to beating rain ot water run-off
GFCI Requirements for Screened Porch mkrawitz Electrical 4 04-23-2010 01:06 PM
How to Winterize Porch subdude Remodeling 0 02-04-2010 09:00 PM
GFCI between porch receptacles Thurman Electrical 4 08-19-2009 12:40 PM
GFCI intermittent nuisance trips jejm1975 Electrical 43 09-07-2008 09:18 AM
GFCI Question Mdbuilder Electrical 6 06-19-2008 03:15 PM
