-   -   GFCI not working (http://www.diychatroom.com/f18/gfci-not-working-28769/)
notasinger 08-18-2007 11:10 AM
GFCI not working
I help maintain the building at our church and we have an issue with exterior GFCI's not working. I find it hard to believe that all 8 outlets around the building will not kick off the power to the outlet when I press the "Test" button.
Is there a way that these can all be bad or are they wired up wrong?
Any help with what to check would be greatly appreciated. Thanks
MgMopar 08-18-2007 12:15 PM
Ether way bad or wired wrong they should be repaired. I would say to start with one outlet and investigate to see if it is wired wrong or just bad. After that you may have a better idea what is up with the others. If you are not comfortable with electricity get some one who is. It is possible they are all bad I have seen that in older homes were all the gfci in all the bathrooms were just bad I guess from age?
