GFCI Not Working. - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 08-01-2011, 07:54 PM   #31
Rewards Points: 6,652
You are going to have to take each one apart to inspect and fix with wire nuts as that one should be. As for finding the hot, it would be the one that when you touch a no-contact, after using wire nuts to cap the ends, is how you find the hot, or using a meter carefully to check. BTW, 1958 BX is not proper to use as a ground, due to it does not have a bonding strap in it.
The Following User Says Thank You to gregzoll For This Useful Post:
teamcampreder (08-01-2011)
Old 08-01-2011, 07:58 PM   #32
I can figure out hot and neutral, but what about line vs load?
teamcampreder is offline   Reply With Quote
Old 08-01-2011, 08:01 PM   #33
That was explained before. Line is input, Load is output.
Old 08-01-2011, 08:26 PM   #34
So when I split it between the 4 wires (2 white two black) the black that shows voltage is line and the black that is dead is load?
Old 08-01-2011, 08:39 PM   #35
That would be correct. Keep in mind that you are playing with live voltage when you are doing this, so be careful when working around the circuit. The best thing to do, is post the wife or someone you can trust to stand by the panel, and when you tell them to flip the breaker, to do so at that time.
Old 08-01-2011, 09:04 PM   #36
WooHOOOOO after a day and a half of hair pulling with the outlet, I finally fixed it. Prior owner must have thought he was hot stuff, he spent the time SOLDERIING the line and load cables together to make it look like one. Seems like a lot of work to do it the wrong way!! Thanks so much guys, I am sure this was especially frustrating for you all, with my lack of experience and all. Lesson of the day... don't just look at the wires attached to the outlet, look at the wires coming into the box too!!
As far as the ground goes, I am going to have to take my chances with the BX armor as ground. Just dont have the money right now to do a full system update.
Thanks again a million guys, your the best! Case Closed!
Old 08-01-2011, 09:10 PM   #37
That is actually how they used to do it in the day. Use a really heavy duty solder iron, and lead solder. Then it would be wrapped in a cloth tape. I remember my dad pulling one of those heavy duty suckers out, to do a power supply for a Heathkit H-89 when I was 12. The puny 35 watt iron would not solder the capacitors, but that heavy duty iron worked for it.
Old 08-01-2011, 10:12 PM   #38
I=E/R
a7ecorsair's Avatar
OMG I did one of those about 1980. 48K and a 5 1/4
a7ecorsair is offline   Reply With Quote
Old 08-01-2011, 10:14 PM   #39
I=E/R
a7ecorsair's Avatar
You're welcome. And now that you found and fixed the problem, you can understand why I was asking about the wires and cables...
Old 08-01-2011, 10:22 PM   #40
Dad took and loaded CP/M on it. It was actually the second home computer in our house, but first that dad & I built together. First one was a Exidy Sorcerer. Yes, it is showing my age. Still remember the day that dad got done building the power supply on the Heathkit. Went to power up, and all I heard was the sound of a shotgun going off. When I went into the kitchen, dad was under the table, and there was oil everywhere. That sucker had some huge Cap's in it.
Old 08-04-2011, 09:43 PM   #41
Question
my GFCI not working
HI there, there is a GFCI Receptacle in my bath room, which connected 4 wires and ground, just no work some day, there are 2 lights and another receptacle no power neither. I opened the GFCI Receptacle and all lights, checked all of them, none with power. I turned on/off all breakers on the panel, nothing happened. I even can not figure out which breaker controls the GFCI, what can I do now?
laoadam is offline   Reply With Quote
Old 08-04-2011, 11:55 PM   #42
Missouri Bound's Avatar
laoadam......you must start your own thread if you want to get responses.
GFCI grounding; and inside double gang box? Wildswalle Electrical 5 05-29-2011 02:25 PM
GFCI no more then 4 wires bryan1282 Electrical 3 03-22-2011 03:15 PM
Motion Light tripping GFCI? Jonobp Electrical 5 09-07-2009 08:52 PM
GFCI between porch receptacles Thurman Electrical 4 08-19-2009 01:40 PM
new gfci on new circuit pops rtoni Electrical 39 11-15-2008 11:18 AM
