GFCI With No Ground Wire? - Electrical - DIY Chatroom Home Improvement Forum
Old 03-12-2009, 03:37 PM   #1
Rewards Points: 150
GFCI with no ground wire?
Hi all,
Just wondering how the GFCI outlet protection capabilies are affected by not connecting a ground. In my kitchen I only have the white and black wire sticking out. I installed one GFCI but I did not connect a ground wire. I do not remember exactly if there were two bare cooper wires connected, one coming from the source and one from the load. I may have to go back and add a wire to connect the ground?.
gante is offline   Reply With Quote
Old 03-12-2009, 03:50 PM   #2
joed's Avatar
Rewards Points: 12,010
The GFCI will function just fine without the ground. It is in fact a legal way to install three prong receptacles when no ground is present.
IF there is a ground present in the box you must connect it to the GFCI receptacle.
Old 03-12-2009, 03:55 PM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,878
Exactly.
Why would you leave it off in the first place?
Old 03-12-2009, 06:13 PM   #4
Rewards Points: 150
Originally Posted by Speedy Petey View Post
Exactly.
The grounds (one from the line and one from the load) were connected to each other. Ther was no wired tap from this two for the GFCI. I just was not sure if I could add a wire to connect the GFCI ground to these two wires. I will go back and add that extra wire for grounding. What gauge are these cables 14 AWG?
Old 03-12-2009, 06:43 PM   #5
Ground gauge...
15 amp breaker= 14 or 12 awg
20 amp breaker= 12 or 10 awg
I would keep the pigtail the same size as the wires in the box.
rgsgww is offline   Reply With Quote
Old 03-12-2009, 09:41 PM   #6
Rewards Points: 1,448
The ground wire from the source and the ground wire to the load remain connected together. Do add one short length of bare or green wire (a pigtail) to connect the GFCI unit ground to these ground wires.
All ground wires are connected together wherever they come together (in junction boxes, etc.).
Old 03-13-2009, 10:17 AM   #7
Rewards Points: 150
Yes, I will be doing this. Thank you
switch lacking ground wire anervoustwitch Electrical 17 02-27-2009 05:12 PM
What to do w/ ground wire in older home? dbldee20 Electrical 16 01-12-2009 07:55 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
Dryer Grounding??? Traci_howdyadothat Electrical 7 05-27-2008 02:14 PM
ground wire handifoot Electrical 2 06-25-2007 10:39 PM
