-   -   Gfci in a masonry wall (http://www.diychatroom.com/f18/gfci-masonry-wall-40929/)
captain25 03-23-2009 01:05 PM
i am attempting to upgrade our current outlet in the bathroom with a GFCI. sounds simple so far? keep reading.
the current layout has an old wall sconce with an outlet (device to be replaced) wired into a junction box that is grouted into a masony wall. the wall is the "wet" wall of the bathroom and backs up to the kitchen. i bought the correct GFCI device to simply rewire in the old wall sconce junction box but the box is too small to fit the outlet.
basically it looks like i need to chip out the old junction box from the wall attempting to not disturb the plaster finish too much. how can i do this? how can i remove the old metal juntion box and install a new one? i have a lot of hand tools and a fair amount of power tools to do the job. of course i don't want to take a sledge hammer to it.
quite simply, how can i "easily" remove a hole in a masonry wall and install a new junction box?
thanks
220/221 03-23-2009 07:33 PM
Slowly and carefully. Hopefully it's doesn't have any brackets that are plastered over. Sometimes they will just pull straight out when tou chip away the surrounding plaster or grout.
Scuba_Dave 03-23-2009 07:41 PM
Can you install another box somewhere else in the bathroom & then daisy chain the old box off the load size of the GFCI?
philS 03-24-2009 12:08 AM
Probably too late to help, but why not buy a GFCI breaker, assuming the upstream daisy chain won't work? Even $50 sounds cheap to me compared with the time it took me the one time I upsized a box in a concrete wall.
