Old 11-20-2011, 12:54 AM   #1
Question
GFCI Looks Correct But Not Working
Here's my situation. I just replaced an existing old GFCI outlet with a new one from home depot. There were 4 wires and one ground coming into the old outlet when I first checked it. I took the 4 wires (two black, two white) and placed both black wires on one side (copper colored screws) and both white wires (silver colored screws) on the other side. I turned the breaker back on and I do get the little green light in the upper right of the outlet. But when I hit "test", the reset button never pops out and when I plug in a light there is no power. I then went and flip flopped the black wires and the white wire positions and didn't get any power. I tried many different combinations and no power. the connections right now look exactly like how they are shown in this youtube video which is frustrating because things don't work
http://www.youtube.com/watch?v=OD-XI...eature=related
The circuit is labeled "lights dinner" which is strange because this outlet is no where near that area. it's in a bathroom on the other side of the condo.
this is a 20amp circuit.
What should I do to fix this and where could the problem be?
thanks
2marshall8 is offline   Reply With Quote
Old 11-20-2011, 03:31 AM   #2
Semi-Pro Electro-Geek
Looking right and being right are different. Each wire must go to exactly the right terminal. There's no flexibility, there's only one right way to connect it.
The incoming power from the breaker goes to the "LINE" terminals on the GFCI. Black goes on the "hot" side (brass screw, narrow slot on the receptacle, the right side when looking at the front of the receptacle) and white on the "neutral" side (silver screw, wide slot, left side). The other cable connects to the "LOAD" terminals on the receptacle, also with white and black on the correct sides. From your description it sounds like you had line and load reversed, then you swapped wires so you had line and load reversed and also hot and neutral reversed.
mpoulton is offline   Reply With Quote
Old 11-20-2011, 08:57 AM   #3
Licensed electrician
As a test put both blacks and both whites on the LINE terminals and see if the GFI functions correctly.
You need to make sure the white is paired on the same line or load terminals as the black. You cannot have line black with the load white.
Old 11-20-2011, 10:38 PM   #4
I ended up finding that I should have hit the reset button when I was changing pairs of wires. So I found the correct incoming hot pair, crimped it down, and hit the reset button, which brought everything online.
thanks
GFCI not working. teamcampreder Electrical 41 08-04-2011 11:55 PM
GFCI Issues SilentPete Electrical 6 10-07-2010 06:09 PM
GFCI Receptical Trip? Giles Electrical 9 06-04-2010 06:25 PM
Whirlpool GFCI circuit info conflict. 3detailer Electrical 29 05-17-2010 10:12 AM
GFCI between porch receptacles Thurman Electrical 4 08-19-2009 01:40 PM
