GFCI Line Side - Electrical - DIY Chatroom Home Improvement Forum
Old 02-17-2011, 05:03 PM   #1
Rewards Points: 172
GFCI Line side
Hello:
I have a question about GFCI outlets. I was looking at some in the store and noticed that on some of them they have the 4 holes on the back for the line side. Is this to add another receptacle on the line side so if it trips that receptacle will not trip? Also, I always thought it was good practice not to use the push in connections on the back.
Thanks!
zephed666 is offline   Reply With Quote
Old 02-17-2011, 05:12 PM   #2
Sfeyelectric's Avatar
Originally Posted by zephed666 View Post
Hello:
Thanks!
Backstabbing is not the best idea; However, that is what that can be used for.
Sfeyelectric is offline   Reply With Quote
Old 02-17-2011, 05:55 PM   #3
Rewards Points: 324
on gfci those are not back stab.loosen screw insert stripped wire into hole,tighten screw.these are called back wired.
oleguy74 is offline   Reply With Quote
Old 02-17-2011, 05:56 PM   #4
Master Electrician
Rewards Points: 3,684
They are not backstab terminals. They are pressure plates wihich tighten down over the conductor when you tighten the screws.
brric is online now   Reply With Quote
Old 02-17-2011, 06:08 PM   #5
Electrical Contractor
kbsparky's Avatar
There is a big difference between back-stab and back-wired terminals.
GFCI's utilize back-wired terminals, which have to be manually tightened once the conductors are inserted.
-KB
Old 02-17-2011, 06:12 PM   #6
I stand corrected!
Old 02-17-2011, 06:46 PM   #7
I=E/R
a7ecorsair's Avatar
Too bad all receptacles aren't made this way. These are really nice to work with
a7ecorsair is offline   Reply With Quote
Old 02-17-2011, 07:13 PM   #8
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Actually back wired receptacles a quite common these days and only the cheap ones are side screw or back stab.
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 02-18-2011, 08:38 AM   #9
Rewards Points: 172
so I can use this GFCI to keep a light on the line side without pigtailing?
(I would only have to pigtail the ground...)
Water line to fridge, actually -in- 'subflooring', not under?? Anonyone Plumbing 5 10-16-2010 07:31 PM
GFCI with 12/2 wire Safety Question Coors Electrical 8 03-09-2010 05:53 PM
Multiple items on load side of GFCI? BimmerRacer Electrical 17 08-29-2009 02:36 PM
Need wiring diagram for protected side of GFCI BimmerRacer Electrical 0 08-28-2009 10:47 AM
GFCI Question Mdbuilder Electrical 6 06-19-2008 04:15 PM
