GFCI/light Switch Combo Not Testing - Electrical - DIY Chatroom Home Improvement Forum
Old 10-23-2013, 02:03 PM   #1
Rewards Points: 664
GFCI/light switch combo not testing
In the kitchen I have an outlet with a GFCI on the bottom and a light switch on top. I wired it according to instructions I received here. The power coming in is from a two wire ungrounded wire. When I test the GFCI portion with my Gardner Bender tester the GFCI does NOT switch off when I press the test button. On the GFCIs in the bathroom this button makes them turn off and I have to reset them to work again.
Does this mean my GFCI outlet is not doing what it should?
crescere is offline   Reply With Quote
Old 10-23-2013, 02:42 PM   #2
Oso954's Avatar
Rewards Points: 768
Press the test button on the GFCI to see if it trips. If it does, then press the reset.
If that works, your GFCI is working properly.
Oso954 is online now   Reply With Quote
Old 10-23-2013, 02:43 PM   #3
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
Best of my knowledge those testers won't work on an ungrounded circuit, the only way to truly test it is with the test button on the GFI.
wirenut1110 is offline   Reply With Quote
Old 10-23-2013, 03:15 PM   #4
Rewards Points: 776
No everything is fine. External gfci testers need a connected ground line to work. The switch in the gfci face simulates a ground fault without the need for a ground hence the difference...
curiousB is offline   Reply With Quote
help with light/outlet switch combo aftermath431 Electrical 5 07-06-2012 12:23 PM
two switch ceiling fan/ light question ifthenelsenull Electrical 4 12-29-2011 04:23 PM
Novice Electrician (UGH) Replacing Fan/Light combo switch jeffntonya23 Electrical 0 04-16-2011 05:42 PM
fan/light switch buzzing mjlocat Electrical 4 05-23-2010 03:44 PM
Replacing a bathroom fan switch cmacjr22 Electrical 4 11-04-2008 07:14 PM
