-   -   GFCI/light switch combo not testing (http://www.diychatroom.com/f18/gfci-light-switch-combo-not-testing-189111/)
crescere 10-23-2013 01:03 PM
In the kitchen I have an outlet with a GFCI on the bottom and a light switch on top. I wired it according to instructions I received here. The power coming in is from a two wire ungrounded wire. When I test the GFCI portion with my Gardner Bender tester the GFCI does NOT switch off when I press the test button. On the GFCIs in the bathroom this button makes them turn off and I have to reset them to work again.
Does this mean my GFCI outlet is not doing what it should?
Oso954 10-23-2013 01:42 PM
Press the test button on the GFCI to see if it trips. If it does, then press the reset.
If that works, your GFCI is working properly.
wirenut1110 10-23-2013 01:43 PM
Best of my knowledge those testers won't work on an ungrounded circuit, the only way to truly test it is with the test button on the GFI.
curiousB 10-23-2013 02:15 PM
No everything is fine. External gfci testers need a connected ground line to work. The switch in the gfci face simulates a ground fault without the need for a ground hence the difference...
