Old 02-23-2014, 09:27 AM   #1
Retired NYPD
Share |
Gfci kitchen counter
The gfci on kitchen counter top is working, but the 2 outlets on the island do not work. The outlets on the counter all work. Can the gfci be faulty? The gfci does work the island outlets, I know from previous work I did. Should I replace gfci? Thanks for any advice. Frank.
FrankLa is offline   Reply With Quote
Old 02-23-2014, 09:38 AM   #2
Licensed Electrician
k_buz's Avatar
How many GFI's are on the counter...not GFI protected receptacles, actual GFI's?
Old 02-23-2014, 09:49 AM   #3
Retired NYPD
Just one.
Old 02-23-2014, 09:50 AM   #4
k_buz's Avatar
I wouldn't suspect the GFI is bad if the other counter recepts are protected by the single GFI and working.
Old 02-23-2014, 09:55 AM   #5
Retired NYPD
That is what I thought. I will check the 2 outlets on the island. Thanks.
Old 02-23-2014, 10:05 AM   #6
MarginallyQualified
Originally Posted by FrankLa View Post
Just one.
There should be at least two "small appliance" circuits
with each protected by their own GFCI device.
TarheelTerp is online now   Reply With Quote
Do all outlets in kitchen need to be GFCI protected? ponch37300 Electrical 2 05-12-2013 02:42 PM
GFCI knowledge please bobgodd Electrical 14 02-04-2013 03:52 PM
Another GFCI Question Jzone99 Electrical 5 09-16-2012 01:56 PM
Replacement of flush mounted cutting board in kitchen counter top Humby Kitchen & Bath Remodeling 1 07-31-2010 02:45 PM
Ontario CE code for kitchen counter outlet height? mrgadget Electrical 5 03-20-2010 10:19 AM
Copyright © 2003-2014 Escalate Media. All Rights Reserved.
