GFCI Hot Tub Breaker - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-10-2012, 04:39 AM   #16
Electrical Contractor
kbsparky's Avatar
If the heating element is directly connected to the circuit board, that is most likely your culprit. Many hot tubs are configured this way.
The element needs to be replaced.
Try disconnecting the element (both leads) from the circuit board and test again.
Old 08-10-2012, 07:48 AM   #17
I've recently purchased a hot tub and I'm in the process of building a deck and running electric. This tub can run on a 40A, 50A or 60A circuit, all dependent on what the owner wants or has available. The 40A current draw enables just one of the pumps and the heater to run. 50A set up is both motors at once with no heater and the 60A allows all three to run at once. Your tub may or may not run at 40A or 50A, but it would depend on how it has been set up. If you have wire ran to the tub that will support 50A, your tub may run more components when in use.
Either way, use a GFCI.
OKDrew63 is offline   Reply With Quote
Dimming lights on one circuit, GFCI breaker tripped boatman537 Electrical 4 06-05-2012 10:43 AM
GFCI Breaker Gzuber Electrical 7 05-30-2012 10:38 PM
Switch triggering GFCI breaker on a DIFFERENT circuit stillmarried Electrical 5 11-29-2009 09:14 PM
GFCI Breaker & GFCI Outlet together??? abinpa General DIY Discussions 6 04-12-2009 08:59 PM
GFCI Recepticle vs. Breaker WaldenL Electrical 19 01-18-2009 12:04 PM
